Maestro A+ Will It Fit
Posted 17 November 2009 - 09:31 PM
can i fit a maestro 1275 a+ in the mini and what mods do i need to make to the engine to fit
cheers
Andy
mate has a complete car for stripping
Posted 17 November 2009 - 09:58 PM
Posted 17 November 2009 - 10:33 PM
Posted 17 November 2009 - 10:51 PM
Posted 17 November 2009 - 11:51 PM
Posted 18 November 2009 - 07:53 AM
You may have a little fun getting an oil filter, but I can get them if you need.
Here's one built up ready to go... almost
Posted 18 November 2009 - 08:02 AM
It has been done, There's was an article in mini world a number of years ago, and I believe there is a thread on here somewhere ( was in either a pickup or a van )
The main problem is the engine needs to be installed backwards ( ie, carbs at the front, dizzy and plugs at the back ) because the gearbox is bolted on the side and therefore does not have the 'reverse of drive' which is achieved with the transfer gears and the 'under the engine' gearbox in the mini, the gearbox is directly connected ( through the clutch ) to the crank.
I'll have a search for the post..
Found it..
http://www.theminifo...x...&hl=maestro
It actually turned out it was not a complete maestro install, but similar to what I'd done above, converted the Maestro block and then he had mounted a 5 speed Mini gearbox onto the bottom, not used the Maestro gearbox.
Edited by GuessWorks.co.uk, 18 November 2009 - 08:11 AM.
Posted 18 November 2009 - 12:53 PM
Posted 18 November 2009 - 03:18 PM
Posted 18 November 2009 - 03:25 PM
Posted 18 November 2009 - 05:42 PM
The engine above I supplied with 5 spare filters so the owner didn't have to go searching for them when an oil change was required.
The modification to the cap is only small...
Plus, Meastro engines are failrly cheap, I pick them up every so often off ebay for pennies, think the last one I bought cost £10, and that was as out the car, gearbox, ignition modules, auto choke carb etc etc. dizzy is also the same type as the MK1 Metro Turbo.
Edited by GuessWorks.co.uk, 18 November 2009 - 05:45 PM.
