what wheels to buy?
Posted 13 October 2005 - 04:38 PM
Thanks for your help minimac
:worship:
Posted 13 October 2005 - 05:01 PM
mine was an extreme case but i went down a hole in the road and come mot time it failed with a SNAPPED front subframe, i blame this on my 13"ers (might be wrong) but i felt like C**p when i had to spend £500 on a rover front subframe plus labour! back then i couldn't get hold of a genuine subframe from anywhere ( now they are ten a penny )
ps they don't noticably slow you down but they do naturally weigh more so i guess they do.
if you do go for 13"ers you'd be wise to uprate your front tie bars and fit some decent shockers with some hi los. (i did all this but my swivel pins still needed adjusting and replacing every time i hit a pot hole :sad: )
oh yeah and your arches will need cutting and rustproofing and new wider wheel arches will need to be fitted such as the common sportspack arches. looks amazing when finished but personally i'd stick with 12"ers and lower and stiffen the suspension with uprated tiebars, shocks and hi los.
have fun mate, thats what its all about :grin: :grin:
Edited by Nick The Greek, 13 October 2005 - 05:04 PM.
Posted 13 October 2005 - 05:25 PM
Increasing the rolling circumference of the wheel/tyre will slightly gear the car up (not sure though how much difference there is, not too much to be honest) but it can be compensated for with a different final drive ratio if necessary.
You will have to cut your arches as said above, you will put increased load on steering and suspension components, you will find it slightly harder to steer (more so at lower speeds), you will have to pay more for tyres when replacing them.
But, if it is the look you want to go for, do it!
Bear in mind all that has been said if you do want to go for it. (I did) :grin:
P.S. Minis really were designed for smaller wheels and the purists always say go for 10" wheels, but yours should be on 12"s as standard. Nice 5.5" x 12" wheels look good on a Mini, and you normally get away without having to trim the arches with this size wheel.
Posted 13 October 2005 - 05:39 PM
I haven't found any 5.5"x12" which you can use without having to trim the arches. My 5"x12" revolutions needed me to trim the arches.
Posted 13 October 2005 - 05:40 PM
the arches have to be cut and waxoiled and bigger arches fitted which must cover the tyre by law.
good luck
hers mine
Posted 13 October 2005 - 05:41 PM
On some 5.5" wide mini wheels, you won't have to trim the arches, on some you will. :grin:
Posted 13 October 2005 - 05:42 PM
NICE MINIheres mine
not sure about the roof spoiler though?
Posted 13 October 2005 - 06:11 PM
i had to cut away about an inch at the front of my arches to fit 5.5" by 12"
Posted 13 October 2005 - 06:20 PM
Posted 13 October 2005 - 06:32 PM
Posted 14 October 2005 - 07:44 PM
i'll have to save a bit longer for the DTM exhaust.
I have a playmini dtm backbox for sale if you're interested.
Posted 15 October 2005 - 09:03 PM
Posted 15 October 2005 - 09:41 PM
Posted 16 October 2005 - 10:24 AM
They look stunning, the car can corner MUCH quicker, but the driving pleasure has totally gone. The car is slower. The car tramlines for fun. It cost an arm and a leg to get them to fit properly. Needed new arches, HI-LOs, new shockers etc etc etc.
If you are after looks 1st, buy 13s. If you want looks/performance/driveability, then stay with 12s.
If you like ickle wheels, get 10s, but they cost an arm and a leg to fit aswell.
Posted 16 October 2005 - 11:40 AM
:grin: Force Racing Split rims...I have just picked up my wheels from carl austin (force racing) and they are very nice i say go for 10"
*Jelous* arnt they like 400 quid a wheel?
