Hi guys
I need to replace my fuel filter as its corroded through....
Whats the best way to replace it....simply clamp the fuel sender hose?
Got a Haynes, but just wanted to know if there is way you've done it?
Many thanks
Fuel Filter
cooperdan
, Nov 20 2009 09:19 AM
4 replies to this topic
Posted 20 November 2009 - 09:19 AM
Posted 21 November 2009 - 08:41 PM
Hi guys
Many thanks
If I remember (been almost a year!), the system is pressurised, so best to do once the engine has not been on for a while. Obviously take all precautions!! Is it the filter thats corroded or the pipes/connectors that connect it up?
If it is the connectors/pipes, have a look at this:
http://www.theminifo...;hl=fuel filter
Edited by robtheplod, 21 November 2009 - 08:45 PM.
Posted 21 November 2009 - 09:30 PM
just disconnect it you will get a bit of fuel out but it wont drain the tank it will just be what is in the line
hope this helps
dan
hope this helps
dan
Posted 22 November 2009 - 11:56 AM
Be careful when taking the pipes off. They tend to rust due to there positions.
They can be replaced but when I swapped mine, I had to wait almost a week for delivery and called a few companies.
Also make sure you get the correct fuel filter. There are 2 types for different VIN numbers. Quoute your reg or VIn whne bying to avoid confussion
Mike
Mike
Posted 22 November 2009 - 04:13 PM
Model:city
Year:1991
heloo,
my cars running aroud 115*c this is kinda bad right?
L
All sorted..
Took a while due having to take the bracket off...lol
Thank you for the replies..
