Genuine or non genuine
Posted 16 October 2005 - 05:14 PM
What i i am thinking is to buy non gen panels and then cut out the parts that i need for the patches.
Do you think this is alright to do or should i be replacing whole panels and be using genuine panels aswell.
#2 Guest_Beno_*
Posted 16 October 2005 - 05:19 PM
As for the floor well just cut out the rot and replace !!
Hope this helps you out !!
Posted 16 October 2005 - 05:23 PM
Posted 16 October 2005 - 05:24 PM
Posted 16 October 2005 - 05:26 PM
i was going to get them from minispares.
Posted 16 October 2005 - 05:28 PM
Foors can be patched as can the door step but concider the fact that if there is rot in the panel in one place there will be more just waiting to show, particularly the box sections of the sillsSorry yeah i am going to replace the whole sill as a oner but the floor and the passnger side door step i was just going to cut out the rot and replace.
Best bet is to get the panels, get the old sills off and then asses the rust issue before patching or replacing the lot
Posted 16 October 2005 - 05:30 PM
If you are hapy with a 'it'll do atitude' then they should be ok. Expect to work the panels to get them to fit and dont expect any of the profile lines to matchhow poor is poor though because i cant really afford to do full gen panels.
Posted 16 October 2005 - 05:32 PM
Might just get genuine sills then as the other parts just need patching
Posted 16 October 2005 - 05:34 PM
the last panel i got was a gen full scuttle and it fitted perfect.
hope that helps
Posted 16 October 2005 - 05:54 PM
Is this a really bad idea? I know it is bad to put them on to cover rust.
Posted 16 October 2005 - 06:21 PM
Posted 16 October 2005 - 06:25 PM
Non gen panels aint all that bad either, depends where you get them.
Afew people will agree, that some GEN panels arent all the best panels around and can be just as poor or worse then a non gen.
MMachine non gen panels were super on my mini.
Posted 16 October 2005 - 06:27 PM
Posted 16 October 2005 - 06:33 PM
Jordie and Tjenkos: Thanks that was the sort of thing i wanted to here. I dont mind a bit of work but surely outer sills wont be that hard beacuse they are straight anyway.
If it were front wings and stuff i would get geuine because of the curves etc.
Posted 16 October 2005 - 06:37 PM
Also to come - Scuttle Panel and Front panel non gen.
I dont think that much work will come with them being non gen. Besides, cutting the old sills out is going to be just as hard so getting the new ones in cant be that hard.
