Painting With Spray Cans?
20 replies to this topic
#1 grainge231
grainge231
  • 251 posts
Posted 07 December 2009 - 08:00 AM
ive noticed a few little rust bubbles that have blistered up leavving me with a few holes in my paintwork some u can get your finger in. Ive been tempted to rub it back and respray but money and equipment being the issue im wondering if it can be done with spray cans with looking to rubbish?
#2 Big Guns
Big Guns
  • 395 posts
  • Local Club: NORTHANTS M.O.C
Posted 07 December 2009 - 08:10 AM
Hi. Loads of people go the "rattle can" way. It, like everything else, is all about good preparation. Do the rub down, prime it, use stoppers and rub flat, then RATTLE away. Leave it to harden PROPERLY then flat back and polish!
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 December 2009 - 08:20 AM
how do you paint a hole :lol:
won't the paint just go through it ?
#4 grainge231
grainge231
  • 251 posts
Posted 07 December 2009 - 08:27 AM
i see what you mean but i think i havent explained very well haha. The bubbling paint has now blistered up and i have holes in some of my paintwork not in the panels them selves :lol: so i should be okay as long a prep very well? Thats good then. I just wanted to know incase i started to do it and it goes pete tong then it would look worse then before. Il start a new topic with pictures when i get round to doing it this thursday n friday let me know what you think
#5 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 07 December 2009 - 01:06 PM
You can get fantastic results with spray cans, it is all down to your skill level.
When you rub the rust down, make sure you get through to clean metal, dont just fill/paint over the rust as it will become worse.
Once the metal is clean, coat it with somethign like por15 metal ready as that will treat the rust rather than cover it up like alot of the rust remedies do.
#6 paul6266
paul6266
  • 482 posts
  • Local Club: Retro Classics
Posted 07 December 2009 - 01:42 PM
like everybody has said its all down to prepwork, i would also allow about 2 or 3 cans per panel by the time you have rubbed back etc, but key to a good finish is to warm up the can and the panel, i used to use a hair dryer, but by god ive seen naff ones that have been painted with rattle cans but also seen good ones.
but......all you need is time and patience, good luck buddy
#7 jaydee
jaydee
  • 8,565 posts
Posted 07 December 2009 - 02:25 PM
Dont use an hiar drier with rattle cans, paint wont dry correctly, causing cracking and bubbling.
Good prep work is everything, and a bar coat would be helpful in order to avoid paitn reaction or any sort of reticulation when painting with cans.
#8 TooFPaste39
TooFPaste39
  • 83 posts
Posted 07 December 2009 - 02:43 PM
Prep the area. And if you're cheap like me, use spray cans. I did this to my 1988 CRX. Flat black and it came out decent.
#9 elgarra
elgarra
  • 121 posts
  • Local Club: N/A
Posted 07 December 2009 - 02:59 PM
The prep is so important, but with cans be prepared to spend much more time on polishing etc.
You can get fantastic (if less durable) results.
#10 grainge231
grainge231
  • 251 posts
Posted 07 December 2009 - 03:07 PM
cheers for all the advise guys ^_^ pictures will be up friday possibly. il let u know how i get on. mabey do a guide on here if it comes out well enough :wub:
#11 brianmini
brianmini
  • 213 posts
  • Local Club: MiniClan
Posted 13 December 2009 - 09:13 PM
I think you can get pretty good results with rattle cans....
Proof is in the pudding.... lol I painted my entire car (other than roof) with Halfords BRG rattle cans. I could have done a better job if i'd had more time, I learned a lot while painting.
I recommend buying a plasticote clip on spraygun trigger. Stops you spray painting your fingertips, also reduces runs and splutters from differences in pressure as you press the button down.
Edited by brianmini, 13 December 2009 - 09:16 PM.
#12 brianmini
brianmini
  • 213 posts
Posted 13 December 2009 - 09:15 PM
Oh and I also rattle can filler primered and white primer coat too.
#13 grainge231
grainge231
  • 251 posts
Posted 13 December 2009 - 09:22 PM
wow, that looks really good, where can you get one of those trigger attachment things from?, unfortunate my minis on hold until about halfway through January :), mines BRG to :D
#14 mattwho?
mattwho?
  • 844 posts
Posted 14 December 2009 - 02:50 PM
wont it cost alot to use cans?
ive got a compressor and a spray gun but its mixing the paint im shizzin about
should i buy cans?
how much did it cost you start finish
#15 Big Guns
Big Guns
  • 395 posts
Posted 15 December 2009 - 10:22 AM
should i buy cans?
Matt, you can spray at my place if you want? Get the paint from either Jawels or Brighton Paint Supplies....They're both pretty good. For everything, 2xlts poly base coat, 2xltrs primer, 5xlt lacquer kit (I need this much because I'm adding metal flake to the top 3/4 coats), 5xlts thinners and 10x sheets of 2000grade wet n dry it's costing £185.00. Not a bad deal!!!
