0-60...
mini_sam
, Oct 17 2005 08:31 PM
13 replies to this topic
Posted 17 October 2005 - 08:31 PM
hey all! i was just wondering what the 0-60 is on say a 1380 race spec engine mini? average?
thanks, sam! :grin:
thanks, sam! :grin:
Posted 17 October 2005 - 08:33 PM
30mins.....
Because you forgot to pull the choke out and u cant get her to fire up
No idea tho, but i guess it depends on weight of car aswell as engine. tyres etc factor in too?
Posted 17 October 2005 - 08:36 PM
wont rolling roads tell you?
lol, yeah, a good race engine, some good rubber and average weight...?
thanks again
thanks again
Posted 17 October 2005 - 08:41 PM
Dont realy no, my mates got a 1380 and he's took back seats out and persex windows and fibre glass front end and he reakons bout 6 seconds, dont no if its true buts it feels preety quick. :grin:
Posted 17 October 2005 - 09:07 PM
You'd be better looking for a 1/4 mile time rather than 0-60...
as with the showdown, there's probably a lot more accurate figures out there and a 0-60 guestimate...
As a guide though I'd expect a well sorted 1380 to get into the 14's for the 1/4, with that your talking webbers, sccr boxes, lightened and balanced bottom end and completely stripped car...
In fact look at the one duds100 had
ENGINE - SMMC Race Engine 1380cc block (+73.5mm) Omega Race pistons Lightenened/balanced/weight matched A+ Rods Lightenened/balanced/wedged/cross-drilled/polished crank ARP Rod bolts 4-bolt steel cetre main strap Billet Steel Ulralite flywheel & backplate AP race clutch kit Custom MED Flowed Race head 36.4mm inlet & 31mm exhaust vales Fully Ported head & re-shaped combustion chambers Fitted with ISKINDARIAN race springs 1:5:1 High lift rockers on competition shaft Piper 300 scatter camshaft 48DCOE webber carb on ingraved brian slark worked inlet manifold ALDON RED race distibutor Sports coil & Silicone leads Facet Silver top fuel pump & regulator/filter Engine covered aprroximately 4000miles with Very strict service intervals Engine runs on millers equivalent CASTROL R race oil 13 row oil cooler with braided lines Full stainless exhaust system TRANSMISSION Jack Night SC/CR gear set 1:1 ratio straight cut drop gears Sailsbury LSD with 3.9:1 crown wheel & pinion and coversion outpput shafts. Diff casing machind to house diff Box & diff re-built ony 150miles ago COOLANT SYSTEM Large front mounted radiator Header tank Competion Ring thermostat fitted SHELL/INTERIOR Fibre-glass removeable front end Carbon-fibre bootlid Full lightenned with inner wings removed, boot floor, rear pockets and seat overhang. Door cards and inners removed Polycarbonate lightweight windows all round (glass front sceen as car is road legal) No soundfroofing, no rear carpet Full roll cage with door bars, rear diagonal & dash bar (currently no fitted) RED top 8 race battery on passenger floor. Magnum ultra-lightweight fibre-glass seats TRS aircraft release harnesses Push button start with aircraft switches Dash mounted fuse box & kill switch(not connected) Sparco Pedals Mountenay dished steering wheel SUSPENSION Spax lowered shocks all round Adjustable hi-los all round 1.5 degree negative bottom arms Extended tie bars Cooper S Discs & calipers Green stuff fast road pads Goodridge braided lines all round. Competition bushes 10x6 white GB alloys Yokohomer A032R Cut slicks. PERFORMANCE 126.4BHP at WHEELS @ 7500rpm Engine 145bhp (estimated) wet weight excluding driver 520kg 1/4mile in 14.104 at 94.8mph (timed at Avon Park) 0-60 in 5.34 sec Top speed 110mph and will reach this very quickly!
Posted 17 October 2005 - 09:22 PM
i know the miglias do 0-60 in 4.5 sec's... and there 1293cc
Posted 17 October 2005 - 09:51 PM
cheers GW! how much would dud100's engine cost to build up? it sounds like a brute!
Posted 17 October 2005 - 09:53 PM
It's not just the engine with Dud's car though..
He has an LSD, and it's very lightwieght!
Posted 17 October 2005 - 09:54 PM
That SMMC race engine is pretty much the same spec as my 1425, think my valves are a different size though. A handy reference there!
That Castrol R race oil, how will that differ from normal oil?
Posted 17 October 2005 - 10:27 PM
The smell!That Castrol R race oil, how will that differ from normal oil?
Posted 17 October 2005 - 10:37 PM
does it give off that lovely strawberry smell, i give my 2 stroke poutaline race oil and smells gorgeous, lol can smell it all the way down the street. its cool overtaking cause you dont get that dirty black exhaust fumes though the window, you get my lovely strawberry essence :tongue:
Posted 17 October 2005 - 10:51 PM
No, but technically how does it differ?
