Monster sound system in a mini
#46
Posted 18 June 2007 - 05:04 PM
samwell
#47
Posted 18 June 2007 - 09:01 PM
#48
Posted 19 June 2007 - 08:08 AM
a lot of them dont appear
#49
Posted 19 June 2007 - 04:03 PM
#50
Posted 20 June 2007 - 07:50 PM
*printed and saved* excellent run through there. Got any of the latest places to buy the fleece as the lidl site seems a little bit out of date. Would love to try something like thins. With a gap year on my hands, could mebe make a small business of it.
samwell
Try Ikea - maybe a bit hard work to go to ikea, but they sell thin (easily stretched) fleece blankets for about £3 each
#51
Posted 12 September 2007 - 10:08 PM
and how much resin would you need for a large back bench build?
cheers
#52
Posted 13 September 2007 - 06:40 AM
if you look on ebay you can get low grade resin for cheap.. low grade should be fine for these as its not structual like a boat is. you'd be needing a fair amount... the little pots you find prob arnt going to be enough...
#53
Posted 13 September 2007 - 06:44 AM
#54
Posted 14 September 2007 - 02:58 PM
cheers
How much resin, a fair old amount, it really depends on what your making but about a litre would get you started, you use shed loads of it.
if you have to build high areas mix some body filler in with the resin, seems to work well.
As for sealing off the enclosure, as mentioned above, you dont need to if your enclosure is sclupted tight, but you can start off with sealed enclosures and sculpt round them to make you set up.
#55
Posted 16 September 2007 - 07:56 PM
Hey peeps..
cheers
cheers for the info!
say i wanted to make a rera bench build with a 12" sub and two 10" subs in how would i make it so it wouldnt have to be boxed behinde each sub?
cheers
#56
Posted 22 September 2007 - 11:09 AM
Hey peeps..
cheers
cheers
bump
#57
Posted 22 September 2007 - 11:18 AM
#58
Posted 13 November 2007 - 06:46 PM
cheers
#59
Posted 24 July 2008 - 06:29 AM
#60
Posted 01 November 2008 - 12:36 AM
