Just Bought A Cooper Sport
Posted 17 December 2009 - 01:11 PM
So, I'll be wanting to upgrade it over the next year, can anybody point me in the direction of a good thread or help me out.
I'll like to know what the best mods are for say £1000-1500, where to spend the money first - suspension, engine, gearbox, brakes etc for a good balance approach. I've built kit cars in the past and had mini's in my youth (over 20 years ago) so am happy spannering.
Posted 17 December 2009 - 01:18 PM
Save your money
Anything you do to it, will devalue the vehicle, and I suspect that you've already coughed out enough on the original purchase.
Posted 17 December 2009 - 01:35 PM
If it's in original condition and not already 'messed' with...
Save your money
Cost me £4100 which I thought was a good price - know what you mean on devaluing - maybe I'll just leave it be then
Posted 17 December 2009 - 01:43 PM
The gearboxes are made of cheese, and are notorious for shooting the diff out of the back of the box...
Good idea to get it up in the air and check for excessive lash ( free play ) in the diff, excessive amounts will usually mean a worn diff pin, replacing the diff pin for a competition grade item is a worthy upgrade, however better still is replace the unit for an x-pin diff.. unfortunately you need to remove the engine to do this...
Other things to watch on them is the condition of the scuttle area ( around the bottom of the windscreen and under the wide rubber strip )
Then it's just the usual things, check ride heights, if it's sitting low at the front then it probably means the suspension cones will need replacing, 10 years is about the average life span...
Posted 17 December 2009 - 02:06 PM
I've just found a great local specialist Mini garage down here in Shoreham with an ex-John Cooper mechanic - Tony Franks - running the place and a forecourt full of gorgeous Mini's, it's booked it with him for the clutch (don't fancy doing it outside in January ) and I'm getting him to check everything else whilst he's at it, and give it a service too. I've read about the pin in the diff, I'll get that checked too.
Posted 17 December 2009 - 02:44 PM
Posted 17 December 2009 - 02:47 PM
as above check the scuttle my mpi seems to have less metal on it every day
Is an external check ok, or do you need to look from the engine bay? because externally it looks perfect.
Posted 17 December 2009 - 05:51 PM
Fresh paint over filler always does. Not that yours is.
Unfortunately if you do not have access to an endoscope to look at it from the inside, from the engine bay, you wont really know. One thing to look for is, with the car jacked up and the front wheel removed, look up inside the wing towards the scuttle. If there are signs of corrosion, particularly holes, its needs sorting.
Posted 18 December 2009 - 12:07 PM
Posted 19 December 2009 - 02:25 PM
If your not too bothered about devaluing the car, (which shouldn't be too much of a concern seeing as £4k is a good price for an mpi in good condition) is to fit a stage 1 kit. Most people will tend to add this upgrade so should't affect the value. Typically this involves replacing the exhaust for a larger bore diameter, upgrading the air filter and changing the manifold to an LCD type. Most mini specialists sell them (minisport / minispeed etc)
Fitting a stage 1 kit will increase the bhp slightly and from a personal point of view makes the car look and sound better )
Edited by jamesmpi, 19 December 2009 - 02:27 PM.
Posted 22 December 2009 - 10:11 AM
Edited by Spannerhead, 22 December 2009 - 11:16 AM.
Posted 22 December 2009 - 10:42 AM
Posted 22 December 2009 - 11:37 AM
top color bot that i am bias;)
Tell me about it, I LOVED that colour when it first came out, really glad I can afford one now! Just waiting for the grit to get washed away from the road and I can take it out for a spin, it's been in the garage tucked up since I bought it last week
Posted 22 December 2009 - 11:44 AM
If i had an MPI, i'd probably removed the Sportspack arches (i never liked the shape of them) and replaced them with Group 2's/5's. Get some anthracite ultralites/superlites too. Underneath the bonnet, i'd try and pick up a Stage kit from Minispares. They're expensive for SPI's and MPI's compared to the Carb kits, but the power increase is substantial.
Edited by skaterava, 22 December 2009 - 11:45 AM.
Posted 24 December 2009 - 09:46 AM
There has been a few comments about the reliability of the gearbox on the MPI, I can give first hand advice that they aren't great. Mine had a problem with the idler bearing which mangled the whole box but fear not as you can pickup complete MPI engines for around £200 (what I did). My new engine had only covered around 25K and I even got all of the ancillaries included.
Happy driving!
Luke.
