Mixture Probs ?
Posted 19 October 2005 - 04:53 PM
Posted 19 October 2005 - 05:24 PM
Posted 19 October 2005 - 06:05 PM
lol :grin:caused by voodoo injection system... only way of solving that is connecting to a fault reader...
voodoo indeed
On the five port heads there is always a slight difference between the middle and outer cylinders when using a 'single' inlet system which causes uneven fuel distribution but not so much as to be that noticable.
I'd suspect an air leak on the manifold gasket try tightening up the nuts from the left and right towards the center, six in total. Another thing could be a leaking exhaust on one of the down pipes.
If GuessWorks forgets that it is an injection system, he should be able to put his vast knowledge to use as to the causes of fouled plugs:cheese:
Do the fouled plugs look dry or wet?
Is the engine running well? Any missfire, uneven idle?
What mileage has the engine endured?
Posted 19 October 2005 - 06:59 PM
Posted 19 October 2005 - 07:09 PM
Posted 19 October 2005 - 07:26 PM
Posted 19 October 2005 - 07:42 PM
Posted 19 October 2005 - 10:37 PM
Posted 16 December 2010 - 01:54 PM
its on the exhaust manifold. To find it look down past the left side of the injection manifold at the exhaust and it sticks out at an angle towards the drivers seat. It has four wires. Cant miss it. Might be worth getting it changed, this may be causing the running problems, they have a tendancy to cause the engine to over fuel when the start to fail
I see mention of the bosch replacement (0258 003 193) O2 over the OEM lambda one, is there a current online supplier of the bosch part anyone knows about that 1. has it in stock and 2. ships international to the states?
I found it on the left side last night, the wires gave it away.
Thanks,
James
Posted 16 December 2010 - 02:21 PM
Posted 16 December 2010 - 03:24 PM
J
