Hi,
I've a 1997 mini 1.3i, recently I've noticed that after changing gear I hear a noise a and feel a clicking.
It's almost as though the clutch pedal is disengaging later, however the car feels like it's changing gears OK.
It's just the noise that's concerning me.
Any ideas where I should look?
Paddy
Clutch Pedal
p_paddy
, Dec 23 2009 01:22 PM
2 replies to this topic
Posted 23 December 2009 - 01:22 PM
Posted 23 December 2009 - 02:13 PM
Have a look so see if there's anything obvious fouling on the pedal, split pin or return spring. You could unbolt the master cylinder so the pedal lifts it to help diagnose if it's related to the pedal or the cylinder.
Posted 23 December 2009 - 04:29 PM
I had something that sounds identical to what you describe happening on my Mini, and it turned out to be the air intake pipe for the heater touching the clutch pedal.
