Very Lumpy Running Sounds Like Running On 3 Cylinders Or Misfiring.
#16
Posted 30 December 2009 - 02:33 PM
#17
Posted 30 December 2009 - 02:34 PM
#19
Posted 30 December 2009 - 02:49 PM
its not too much hassle to take the head of anyway... i changed a gasket at imm in the campsite, took a few hours to take it off, give the head and block a good clean, fit the new gasket and head, torque it up and fire it up. easy peasy
#20
Posted 30 December 2009 - 03:50 PM
#21
Posted 30 December 2009 - 04:07 PM
Just so i dont end up doing something rediculous and ruining my engine whilst its apart could you give me a basic outline on what to remember. I've done a head gasket before but was on an engine on a stand at college about a year ago now so just a couple of reminders would help dearly.
#22
Posted 31 December 2009 - 11:10 AM
How severe would a crack in the dizzy cap be because there is a slight mark on the inside, it doesn't look like a crack but what i can only describe as very slight corrosion 1mm to 2mm deep. Anyone shed anymore light?
#23
Posted 31 December 2009 - 11:24 AM
#24
Posted 02 January 2010 - 10:49 AM
Also any other things I should look into doing as i have the engine in bits and havn't done much maintenance since i brought her. Bearing in mind i'm a student with little amount of cash prior to new years eve and christmas. Im thinking along the lines of port and polishing type jobs.
#25
Posted 07 August 2016 - 05:37 PM
very old thread i understand but did you ever resolve the issue? my car is doing exactly the bloody same
#26
Posted 12 August 2016 - 06:41 PM
Anyone able to shed anymore light? Cant get hold of a compression tester possible day to do it anyway even if the head gasket isn't gone its all experience taking my engine apart.
I've got this problem I'm not firing in 3+4 (closest to the thermostat) be changed the exhaust gasket, spark plugs, going to Change the ht leads I have zero spark or from what I can tell. I'll let you know if I fix it but if not I'll be looking to get a compression test.
