Need To Take A 12v Switched Live
20 replies to this topic
#16 Ethel
  • 26,077 posts
Posted 03 January 2010 - 11:47 AM
You can probably find a bit of wire kicking about, salvage the Yellow/white off the ballasted setup?
I can't see when you'd use a switch, why would you want the ignition on without the MJ? You could always just pull the fuse if they are all separate.
#17 miniJJ
miniJJ
  • 262 posts
Posted 03 January 2010 - 11:53 AM
Could do, forgot about that. :thumbsup:
But when I look at the ford 12v wire coming from the coil, it seems to be quite abit lighter than the 8amp stuff I have, but I'll go 15A for peace of mind.
JJ
#18 Ethel
  • 26,077 posts
Posted 03 January 2010 - 12:04 PM
15A is what they recommend for wiring up their rev limiter. You I could google up the coil pack resistance and work it out.
I = V/r 12A = 12V/1 Ohm
I dare say you could get away with less as the coil is constantly cycling on & off and that's done in the EDIS. You'd have less worry about permanent grounding with 15A.
#19 rasputin22
rasputin22
  • 251 posts
Posted 03 January 2010 - 12:06 PM
You will find the ford wire is not made of brass, instead its an conductively improved wire alloy (i believe using silica, or something) hence you can use a smaller wire for the same current. Plus the insulation sleeve will be thinner.
#20 miniJJ
miniJJ
  • 262 posts
Posted 03 January 2010 - 12:08 PM
Haha, I don't know why I didn't think of working it out, been revising Ohm's law etc for my A level physics exam this month. Apologies, :thumbsup:
JJ
#21 philc
philc
  • 839 posts
Posted 03 January 2010 - 07:47 PM
[/quote]
the reason I have a switch is so that I can eliminate any problems if their ever is any and then i can rule out the mj
