Hi, I have aquired a 1310cc engine in its stripped down form, the gearbox that came with it is an old 22g 1128 remote change box, my car is a 1993 car with rod change so I cannot use the gearbox. The engine is an A series block, I suspect from either a morris 1300gt or old 1275 gt mini, and appears in excellent health, can i use the engine end and gearbox from a 1989 A+ 998cc engine and build my 1310cc up from that????
A Series Engine A+ Gearbox
smj
, Jan 03 2010 06:36 PM
1 reply to this topic
Posted 03 January 2010 - 06:36 PM
Posted 03 January 2010 - 07:08 PM
another one 3rd time this has been asked the last 24hrs lol
yes you can use the 1310 engine and put it on the 998 A+ gearbox
you will need to use the 998 A+ tranfer gears and get a 1275 A+ primery gear as the 998 one wont fit the 1275 crank
you will need to use the A+ transfer cae as well and it is not already been drilled for the breather then drill it to give the engine two breather or get hold of a 1275 A+ tranfer case
i have a set of 1275 ecominy drop gears for a 1275 if you get stuck finding a 1275 primery
