Bad Earth From Battery
chris2009
, Jan 04 2010 11:04 PM
21 replies to this topic
#16
Posted 08 January 2010 - 06:04 PM
It can't be carb icing - if it's not running !
#17
Posted 08 January 2010 - 06:06 PM
Good plan i shall give it ago tomorrow morning if the carb has iced up how would you go about fixing this just so i dont have to test it then log back on and ask again i can just get it done.
#18
Posted 08 January 2010 - 06:08 PM
IF you are sure about sparks - then must be fuel shortage - pour some petrol down the carb (or just squirt in some carbchoke cleaner) and crank it - does it run for a few seconds ?
#19
What actually is carb icing then?
#20
Posted 08 January 2010 - 06:13 PM
No doesn't start at all just keeps cranking the engine over and over. Doesnt even get the occasional splutter of her trying to start!
#21
Posted 08 January 2010 - 06:29 PM
Carb icing - is when ice builds up on the carb in cold/damp weather - and blocks the throttle plate . Engine slows/cuts-out - ice melts - engine runs fine again!
Edited by bmcecosse, 08 January 2010 - 06:33 PM.
#22
Posted 08 January 2010 - 10:29 PM
Doesn't have to be running for ice to start building up especially on prolonged cranking.
