Rough Running- Stage One Kit
19 replies to this topic
#16 stocky
stocky
  • 338 posts
Posted 12 January 2010 - 04:01 PM
Is the timing ok?
#17 bmcecosse
bmcecosse
  • 9,699 posts
If no lift pin - use the thin screwdriver blade I mentioned earlier! That's why I mentioned it!!!!!!!
#18 finch661
finch661
  • 2,339 posts
Posted 12 January 2010 - 04:03 PM
cool, and the timing has been set as per haynes with a timing light!
oh and calm down bmcecosse, i was just simply asking a question
#19 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 January 2010 - 04:29 PM
Timing set 'as Haynes' ??? Presumably - by the 'professional'!!!!!!!!!!!! :geek: :D
You should set the timing by advancing it until it pinks - then retard it very slightly so it 'doesn't quite' pink. It's then optimised for your engine - within the limits of the advance curve in your dizzy of course. Make sure the vacuum advance is working ! Without it - the engine will be 'dull'.
#20 finch661
finch661
  • 2,339 posts
Posted 12 January 2010 - 04:36 PM
i will double check the timing, though i usually use a vacuum gauge to check timing/mixture
