Twin Inlet Manifold Help
Posted 14 January 2010 - 09:36 PM
Posted 14 January 2010 - 09:38 PM
will inch and quarter carbs work well with an inlet manifold for inch and half carbs?
Posted 14 January 2010 - 10:21 PM
Posted 14 January 2010 - 10:25 PM
hes found a twin inlet manifold for sale, but it is slightly bigger, i cant see this restricting flow or anything as its bigger.
it should all physically fit together tho shouldnt it
Posted 14 January 2010 - 10:30 PM
B SERIES TWIN 1 1/2 INCH SU CARB INLET MANIFOLD. bmc.
Posted 14 January 2010 - 10:32 PM
Yes - it will fit together. You could consider blocking off the cross tube with cataloy - and then smoothing it out to make two nice straight inlets! The ideal inlet for twin SUs is like a Weber inlet -two long straight tubes! It's the daft crosstube that messes up the air flow.
right cool, i always wondered about that when i saw pictures, bit of foam filler should sort it (just kidding)
ill let him know in the morning when he gets home from work
thanks for your help
Posted 14 January 2010 - 10:37 PM
Posted 14 January 2010 - 10:50 PM
Posted 14 January 2010 - 10:51 PM
Posted 15 January 2010 - 02:28 PM
Not if both are HS type.
isnt the hs2 vertical holes and the hs4 diagonal ?
hs2 manifold
http://www.minispare...ty=pb&pid=33131
hs4 manifold
http://www.minispare.....20INLET HS4/6
Edited by camp freddy, 15 January 2010 - 02:35 PM.
Posted 15 January 2010 - 02:43 PM
That's just plain wrong.............
@campFreddy:
You'r dead right!
HS2 (1 1/4") = vertical stud pattern
HS4 ( 1 1/2") = angular stud pattern
The H4 (1 1/2") has a vertical stud pattern.
However, a minifold like in the second link can be drilled to take HS2s
Oh and once again... Twin SUs need a balance pipe to stay in sync...
Edited by Asphalt, 15 January 2010 - 02:49 PM.
Posted 15 January 2010 - 03:38 PM
Posted 15 January 2010 - 04:20 PM
Posted 15 January 2010 - 04:41 PM
That's the safest way, yes. There are also a lot of non-mini twin carb manifolds for the A-series engine which don't fit a Mini. A Mini needs them to sit at 30°, Sprite etc. manifolds only give 20°, and the jets foul a Mini's bulkhead
right oh, thanks a lot, i found one for a sprite and he said on it will fit mini, when i questioned him it turned out they wouldnt because of the bulkhead issue
being for a mk1 its not something my dad wants to do
