Twin Inlet Manifold Help
#16
Posted 15 January 2010 - 05:21 PM
#17
Posted 15 January 2010 - 06:37 PM
Not if both are HS type.
That's just plain wrong.............
@campFreddy:
You'r dead right!![]()
HS2 (1 1/4") = vertical stud pattern
HS4 ( 1 1/2") = angular stud pattern
The H4 (1 1/2") has a vertical stud pattern.
However, a minifold like in the second link can be drilled to take HS2s![]()
Oh and once again... Twin SUs need a balance pipe to stay in sync...![]()
I like to show proof that I am right ,before I contradict some one.....
I have twin hs4's and a hs2 off the old engine so I knew they were different
but as said the hs2 and h4's are the same..
Edited by camp freddy, 15 January 2010 - 11:09 PM.
#18
Posted 15 January 2010 - 06:40 PM
Yes - sorry H4 type and H2/HS2 are same - but some twin inlets (the ones with square flanges) can take both types. And no - a balance pipe is NOT required! Why would it be ? It's the balance pipe that that ruins the air flow - where it intersects the main flow into the head!
the balancer pipe probably allows for slight imbalance.
#19
Posted 15 January 2010 - 09:07 PM
Edited by bmcecosse, 15 January 2010 - 09:08 PM.
#20
Posted 15 January 2010 - 09:09 PM
#21
Posted 15 January 2010 - 09:10 PM
#22
Posted 15 January 2010 - 09:25 PM
here we go again, lol
deserves to be quoted, made me laugh
#23
Posted 15 January 2010 - 11:11 PM
ha ha
#24
Posted 15 January 2010 - 11:31 PM
ha ha, glad that's sorted.... LOl..
Feeling Left out...
#25
Posted 15 January 2010 - 11:37 PM
Feeling Left out...Why does everything end up as an argument at the moment?
I love TMF,
#26
Posted 15 January 2010 - 11:41 PM
Edited by Sherlock, 15 January 2010 - 11:47 PM.
#27
Posted 15 January 2010 - 11:46 PM
Ive read in vizards guide that your actually better off with a bigger single carb, and twins, something to do with the flow.
#28
Posted 15 January 2010 - 11:48 PM
What does the ballence actually do?
No comment !
#29
Posted 15 January 2010 - 11:56 PM
No comment !![]()
Sorry can't help myself, I need to reply !!
I believe Vizard states that a single 1 3/4 carb on an MG Metro manifold (which he states is fairly good)
would be suitable for an engine up to 1380 cc..
#30
Posted 16 January 2010 - 12:24 AM
As I still seem to be in possession of my head, I'll stick my neck out a bit further, variable jet carburettors such as Amal, will work without a balance tube because the piston / needle assembly is positively controlled by a cable, SU pistons are vacuum controlled & without a balance tube, you will probably never get the two pistons to synchronise accurately, although the engine will still work, best at full throttle, not so good at lower power settings. Someone will come along in a minute & tell us all how wrong I am, but my information comes from personal experience & I do believe that companies like BMC & SU spent a lot of money & time on development of such things, so I tend to go with their recommendations. I also have a book, written by one of the original Mini tuners & race drivers, Clive Trickey. As far as I'm concerned, his ideas still hold good today!
