I have noticed over the last week weeks that my MPi stutters and "pops"
When going in 3rd or 4th at 2000rpm, there is a very noticable stutter or choking. It feels as if the car is running out of fuel. Above about 2300rpm its completely fine. If i put my foot down whilst it is doing it, it takes a while for it to kick in.
I dont know if this is anything to do with it but also if i go down a hill without touching the throttle you can hear rapid popping coming from the exhaust. Not sure if this is normal or whether it has any link to the above.
Just to add to this topic, is there a gearbox steady anywhere? If so where?
Sam
Hmmm, Stuttering?!
sambarnes
, Jan 14 2010 09:47 PM
5 replies to this topic
Posted 14 January 2010 - 09:47 PM
Posted 15 January 2010 - 01:00 AM
Not sure about the MPI specifically but there are 3 possible locations for gearbox steadies 2 facing rearward and one by the oil drain plug. all are easy to spot and look similar to the engine steady.
Could your running problem be an air leak causing the fuelling to go lean on part throttle?
Posted 15 January 2010 - 10:10 AM
Sounds morelike it's running rich, have you had the plugs out for inspection?
Posted 16 January 2010 - 01:12 PM
Agree its runing rich. IS the engine standard?
Posted 16 January 2010 - 05:41 PM
No i havent had the plugs out, i will do that wheen i get time.
The engine is completly standard. Only mod is a cat-back DTM Exhaust.
Posted 17 January 2010 - 07:14 PM
if the it is running rich, how would i get it sorted out?
