Want To Build A Supercharged Engine
Posted 18 January 2010 - 12:29 PM
can anyone suggest or add anything else I should be looking into?
Posted 18 January 2010 - 01:35 PM
A 1380 is fine for reliability if built properly, but IMO if you are going forced induction, why go to all the additional expense of building a 1380 when you'll get planty of power from a 1293.
Posted 18 January 2010 - 01:41 PM
what you mention with regards to why go 1380 is something else I forgot to mention. Cost. I think if I can get the power I want out of a 1293 then the extra it would cost to go 1380 could be spent on upgrading/improving the internals for a more reliable everyday engine.
Through extra reading I have noticed a book is mentioned (one by David Vizard I believe) which I think would also aid me with building this engine. Does anyone know if it includes information on forced induction on a a series?
also is 100bhp (at the wheels) fairly easy to achieve? also what sort of performance figures can I expect roughly?
Posted 18 January 2010 - 03:10 PM
Typically supercharged 1293 motors produce around 130bhp at 10psi, which is pretty decent.
I would suggest that this would get you to 60 in 7 ish seconds or better.
If this is for a daily drive (and I'm sorry if it appears that I bang on about this all the time) but you should at least consider a turbo. you will get 30 to 50% beter fuel econmy for one.
Posted 18 January 2010 - 05:22 PM
having a look at the moment on the 2 websites you mentioned and its helping a lot. thank you for this.
I'm thinking at this stage best bet is to source a 1275 engine, strip it down and see what's what.
What sort of price should I be looking at for a 1275? and are there any particular versions I should be on the lookout for or does it not matter as it will be modified?
thank you:)
Posted 18 January 2010 - 10:50 PM
it will cost you the same to go 1293 or 1380.
Ill always go 1293 over 1380 for the simple reason, if it all goes pop the block may be serviceable afterward.
Posted 19 January 2010 - 12:25 AM
For a core unit 150 pounds.
thanks for the response. i'll start looking for the engine.
Posted 19 January 2010 - 08:29 PM
Posted 19 January 2010 - 09:06 PM
Posted 31 January 2010 - 01:09 PM
its handled the sc for a couple of years now with no problems, and its 165bhp!!!
just make sure your bottom end is strong!
Posted 31 January 2010 - 02:00 PM
Andy
Posted 31 January 2010 - 03:42 PM
Posted 31 January 2010 - 05:21 PM
whats the lifespan in a 15psi install expected to be
Posted 31 January 2010 - 05:47 PM
Posted 31 January 2010 - 07:36 PM
