1.5.1 Rockers With Kent 276 Cam?
Posted 18 January 2010 - 08:50 PM
Posted 18 January 2010 - 08:52 PM
Posted 18 January 2010 - 08:55 PM
thanksIm going to be running that combo, just make sure you dont use high poundage springs.
damn I got double springs haha
Posted 18 January 2010 - 08:57 PM
Is it going to be on a road car?
Edited by danrock101, 18 January 2010 - 08:57 PM.
Posted 18 January 2010 - 08:58 PM
Posted 18 January 2010 - 09:00 PM
nice one, thanksyep
Posted 18 January 2010 - 09:09 PM
Posted 18 January 2010 - 09:14 PM
Posted 18 January 2010 - 09:15 PM
Posted 18 January 2010 - 10:00 PM
I would NOT use 1.5 rockers! Just use the cam as designed - and save loads of valve train wear.
YOU might not. But they must be selling otheriwise people wouldn't stock them.
They may wear on higher lift cams, I mean you wouldn't want 1.5's with a 296 or 310 scatter would you? I cant see there being catastropic wear, thats what the roller tips are for, to reduce side loading and valve guide wear. You will get wear if you use high poundage springs (easy to understand that).
Edited by Pauly, 18 January 2010 - 10:01 PM.
Posted 19 January 2010 - 07:55 AM
Posted 19 January 2010 - 09:12 AM
Why not?
Edited by Paul Wiginton, 19 January 2010 - 09:13 AM.
Posted 19 January 2010 - 10:42 AM
Posted 19 January 2010 - 11:02 AM
I read years ago that the Kent cams were all designed to be run with 1.5s (it may be in Vizards book). In any case the Kent cams always work better with 1.5s from my experience and with the correct springs shouldn't cause additional wear to anything other than the guides if not using roller tip rockers.
I thought I read that somewhere aswell.
