Outer Cv Thread
Posted 20 January 2010 - 07:40 AM
It's on a '94 SPI if that makes a difference?
Posted 20 January 2010 - 12:54 PM
There's only one CV so the threads must be the same.
Posted 20 January 2010 - 01:33 PM
ThanksDoes anyone know what the thread is on the outer CV joint. ie where the castle/hub nut screws on?
Posted 22 January 2010 - 05:59 PM
Posted 22 January 2010 - 07:40 PM
Posted 22 January 2010 - 08:40 PM
M22 is either 1.5 or 2.5mm per pitch
It's not close
What did you measure Dan ?
M22 could of course be available in a 2mm pitch but then that isn't the standard
Posted 22 January 2010 - 10:04 PM
I meant that judging from the fact that all CV joint nuts fit all CV joints and that as you rightly say Martin the joints now appear to be 22mm in diameter, I don't think they are being made to a standard metric thread. M22 comes in four standard pitches and none of them match the imperial very closely, certainly an imperial nut wouldn't fit them. So I imagine the stubs are being machined to a thread using the old imperial pitch on a 22mm shank. This would have to be a custom tooling obviously but my point is that since the difference in diameter is something around 8 thou, the extra depth of the thread (due to the same pitch being used on a smaller stock and thread depth being based on pitch) into the shaft will be within the tollerance of the original imperial thread and so won't cause any weakening due to a smaller cross section. Essentially, within the scope of the engineering in question, 22mm stock is within tollerance to be classed as 7/8". I'd imagine someone at Rover engineering has found that producing CV joints to 7/8" is extremely expensive in a metric world and has done the calculations to find out if the original nut and so the original thread will be up to the job on a 22mm shaft in order to save money. After all, they did start producing the nut with its original thread inside a 34mm bar for presumably the same reason.
What is odd is that the wheelbearings still seem to fit, nomatter how old the CV joint is.
Posted 23 January 2010 - 03:41 PM
Posted 23 January 2010 - 04:55 PM
I measured the OD of the thread and it was 22.05mm. The top limit on M22 thread would be 22.00mm.
Edited by Neilson, 23 January 2010 - 04:55 PM.
Posted 23 January 2010 - 05:41 PM
Posted 23 January 2010 - 06:39 PM
That depends on the tollerance. 7/8" is 22.225mm.
Posted 23 January 2010 - 08:25 PM
all threads require a working clearance.
