i have just fitted hi los all around, however when i go over short speed bumps it bottoms out.
How can i sort this,?
Hi Los
aaron876
, Jan 22 2010 01:37 AM
1 reply to this topic
Posted 22 January 2010 - 01:37 AM
Posted 22 January 2010 - 01:45 AM
Sounds like a bit of an obvious one,
But wind the hilo's up a bit to raise the car and gain clearance.
Unfortunately if you regularly have to get over speed bumps can't have the car as low as you might like.
EDIT: If you mean when going over quite small speed bumps the supension is bottoming out rather than the underside of the car hitting the bump then you have two options.
1.Fit lowered dampers (shorter length to prevent the shocks reaching the end of their travel)
(Or lowered type brackets for the front)
2.Go slower over the bumps (cheaper option)
Edited by Tim1970, 22 January 2010 - 01:52 AM.
