2 Clock To 3 Clock Conversion
16 replies to this topic
#1 joecowan
joecowan
  • 128 posts
Posted 23 January 2010 - 11:50 AM
Model: City E
Year: 90
I bought a set of 3 clock guages for my Mini City E. i Came with the stock to clock lay out. i was wondering if i need to get a new wireing loom for it and were i get a tacho cable from.
Also my clocks are max out at 90 mph but the new one max at 110. will i need a new speedo cable aswell
Edited by joecowan, 23 January 2010 - 11:52 AM.
#2 Llewellyn
Llewellyn
  • 45 posts
Posted 23 January 2010 - 12:12 PM
Easiest thing to do is get a gauge set from a same ge mayfair. That way the can plug straight in as the tacho wire is tucked behind the dash.
What age clock have you bought.
#3 Joloke08
Joloke08
    Not banned but still weird
  • 828 posts
Posted 23 January 2010 - 12:28 PM
As Llewwelyn said you really need to get a set of smiths tripple clocks as the ones you have spound like they are nippon clocks from a later 1275 and you will never get them to read correctly :)
I bet somewhere on here there is somebody who has the ones you need and needs the ones you have,worth asking around :P
The wiring for the tacho is almost certainly already there just look for two wires tied out of the way,one with a spade one with a bullet close to the clocks :lol:
they will only fit on one way :(
#4 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 23 January 2010 - 12:45 PM
yer can get gt clocks to read in a city. i have gt clocks and a metro engine.
you will need to change the speedo drive not the cable. and im afraid this is an engine out job but if i was you i would plug it in and see how far out it reads. a working speedo isnt a mot requirement so you dont need to worry about that. it just might be that youll be doing 30mph and the clock will say 28. but youll soon get used to this.
i use the revs to guess my speed more, i drove for a year without a speedo and i could get those speed dectector things to read 30 every time.
and the rev counter wires should be behind your dash.
#5 Pauly
Pauly
  • 4,213 posts
Posted 23 January 2010 - 02:40 PM
A 90's city will have nippon clocks not smiths, nippon seiki clocks came in 90 and 110 mph versions. Your speedo will read out BUT you can swap your speedo over, just take the front off and theres only 2 screws at the back that holds the speedo in, then you can keep your mileage and more or less accurate speedo readings.
The 2 wires should be tucked behind the cluster for the rev counter. (Taped up usually).
#6 Joloke08
Joloke08
  • 828 posts
Posted 23 January 2010 - 03:34 PM
Fair play i thought they were still on smiths clocks :thumbsup:
But as Pauly said there is the option to use your own speedo but the rev counter from the thre pack you have ;) Still not sure itll read correctly though? i recently saw a 998 with a 1275 tacho and it showed the idle at about 1500 rpm when you could clearly hear it wasnt :(
If your car has smiths gauges you need smith gauges if it has nippon you need those but as others have said get the three pack from a 998 mayfair :lol:
#7 joecowan
joecowan
  • 128 posts
Posted 23 January 2010 - 11:50 PM
My new clocks are from a older copper.
can i take the speedo out the cluster i have ATM and put it in the new 3 clock cluster. id rather do this as the cars only done 40k and the new clocks read at 75k. would jus devalue the car a bit.
#8 Pauly
Pauly
  • 4,213 posts
Posted 24 January 2010 - 07:59 PM
Do you have a picture of these clocks? If they are the same style as your current clocks it will be alot easier to just change the speedo over.
#9 joecowan
joecowan
  • 128 posts
Posted 26 January 2010 - 10:55 PM
yeh these are the new clocks. my old ones are very similar. the just dont have the tacho and the old speedo only goes up to 90. if i swap the spedo between each cluster will the i be able to sace my old millage
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 January 2010 - 11:05 PM
No that's not always the case.
You will notice that the tacho is a seperate pod from the rest. Just use the tacho and the 3 clock PCB from the back. Keep the rest of your clocks, then everything will definitely work and you'll keep your own odometer. And it's easier than stripping the speedo head out of them both and swapping them. If you are using this in the original type (but now 3 clock) binnacle rather than with a flat dash you will need the three clock version of the mounting bracket as it's different.
#11 The-Womble
The-Womble
  • 646 posts
Posted 26 January 2010 - 11:53 PM
I've got a spare mounting bracket going for a few quid if you need one :thumbsup:
#12 joecowan
joecowan
  • 128 posts
Posted 26 January 2010 - 11:58 PM
ive alredy got one but i dont think ill need it cause i got a flat dash
#13 The-Womble
The-Womble
  • 646 posts
Posted 27 January 2010 - 12:02 AM
no worries :thumbsup:
#14 Pauly
Pauly
  • 4,213 posts
Posted 27 January 2010 - 03:45 PM
Seeing as the clocks have the binacle off, you just clip off the clear covers, remove the black outer bezel, 2 screws on the back of the speedo and its out, switch them over job done.
Edited by Pauly, 27 January 2010 - 03:46 PM.
#15 NicholasWilks
NicholasWilks
    Starting My Mini Up
  • 4 posts
Posted 31 January 2010 - 11:07 PM
Hi,
I have just got the same 3 clocks as above and want to fit them to my 1992 British Open Classic, does anyone know how to go about doing this, in the sense of there being tacho wires and actaully mounting (would i have to get a dash?).
Also, how does the 3 clock set up fit to the rear of a dash?
Thanks!
