Emmisions Help
18 replies to this topic
#16 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 30 January 2010 - 08:54 PM
here are our readings this is for an 1100cc mini
CO from 2.00 to 4.00
HC less than 1800
CO2 more than 11.00
#17 tommy13
tommy13
  • 878 posts
Posted 31 January 2010 - 11:21 AM
Did the tester recheck the HC at a higher engine speed? see below from the manual
Note: If a vehicle meets the CO requirement at its normal idling speed but fails the HC check, re-check the HC level at a high idle speed of 2000rpm. If the HC reading is then 1200ppm or less, the vehicle will meet both the CO and HC requirements.
This usually gets most of the stragglers through.
#18 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 31 January 2010 - 12:29 PM
Yeah he did.
#19 mini_mad69
mini_mad69
  • 5,417 posts
Posted 01 February 2010 - 08:22 PM
Failed again today.
I wasn't there as my dad took it in for me. He said he leaned it right off almost stalling and it still failed, over 2000 this time.
So I've advised him to do larger valve clearances and advance the ignition a bit more. Might be a weak spark aswell, so I've asked him too look at the points as they are the ones I got with the 1380 and on the 1275 engine.
He can't be bothered though, so looks like im going to be going back and either changing the cam or finding another engine to drop in.
Edited by mini_mad69, 01 February 2010 - 08:26 PM.
