Your Thoughts On Expeected Hp
Posted 01 February 2010 - 05:26 PM
is a 998 block full reconned.
a 940 block with the larger valves 32mm
head has beeen ported and double valve springs.
a piper 270 cam supposed to add 10bhp.
if has a hif44 with K&N.
LCB and sports exhaust.
looking in to dizzys atm.
wha bhp u think
don;t even know wha standard bhp these 998 A+ engines are.
Posted 01 February 2010 - 06:02 PM
Posted 01 February 2010 - 07:09 PM
Round about 38bhp.The wifes is a 998cc with a 12g295 head (lightly modded) and a stage 1 kit fitted witha Maniflow exhaust sytem.Running standard Metro electronic dizzy.When it was rolling roaded last Nov it had 55bhp at the wheelsany one know the standard hp of a 998 A+ engine
HTH
Pete
Posted 01 February 2010 - 07:13 PM
must have been nearly 70 at the engine.
tha impressive.
did u have a standard cam
and what carb
thanks steve
Posted 01 February 2010 - 07:18 PM
also what kind of rpm are you hoping to run?
Posted 01 February 2010 - 07:21 PM
that's pretty goodRound about 38bhp.The wifes is a 998cc with a 12g295 head (lightly modded) and a stage 1 kit fitted witha Maniflow exhaust sytem.Running standard Metro electronic dizzy.When it was rolling roaded last Nov it had 55bhp at the wheelsany one know the standard hp of a 998 A+ engine
HTH
Pete
Posted 01 February 2010 - 07:26 PM
the head i'm in the middle of porting and polishing.
copper head gaskest due to the head, has the larger valves.
k&n filter.
so a stage 1 kit would reduce performance. also the cam should produce more power than that i thought.
the cam has a power range from 1500 to 6500 will add 10bhp.
on the carb from i have a hs4 and a hiff 44 i would hav though the 44 be better.
Posted 01 February 2010 - 07:28 PM
A HS4 only marginally chokes a 1275, so you'll be better off with that.
Posted 01 February 2010 - 07:31 PM
Posted 01 February 2010 - 07:43 PM
tha strange. thats all.
Posted 01 February 2010 - 07:52 PM
Going by your spec booton I reckon if it was set-up really well you may be looking at 50-60bhp at the flywheel. I had a friend who built an all-singing all-dancing 1040 with full mappable ignition (MJ), twin 1.25 SU's, MSPD PH2 cam, modded 295 head etc, set-up over a few hours on ML Motorsports rolling road and it managed an estimated 63bhp at the fly, considerably less at the wheels. It was very torquey though with an almost flat torque plot on the graph.
I guess it depends how far you're willing to go to chase power figures. In terms of drivability and real world performance I personally would be looking at getting as much torque from the engine as possible.
Oh, and as advised, ditch the HIF44 and fit a decent HS4 or a HIF38 in good nick if you can find one. AAA needle is a good place to start and if you can justify it, go for MJ or another similar mappable ignition system, so much better if you're chasing power.
Hope that helps a bit
Tom
Edited by Purple Tom, 01 February 2010 - 07:54 PM.
Posted 01 February 2010 - 07:56 PM
Posted 01 February 2010 - 08:03 PM
and what carb
thanks steve
[/quote]
Carb is hif38 and the bottom half engine was purchased from someone on here and is belived to have a kent266 cam and had some crank work done.I just put my head on it after inspecting the bores and its run like a dream since (approx 4500miles).As Purple Tom said though rolling roads are all different.I used http://www.mgcars.org.uk/peterburgess/ and must admit although he made a brilliant job the equipment did look a little dated.
Pete
Posted 01 February 2010 - 08:05 PM
thanks steve
Posted 01 February 2010 - 08:06 PM
the block is a standard size. with new rings and all other new parts etc.
