12g202
21 replies to this topic
#16 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 02 February 2010 - 09:37 AM
Im researching the 12g940 head now, not starting work on the 202 it till I know for sure whats best. BMC, u got any tips for fitting the 12g940?I have a standard 1989 mini30 engine so i assume it is flat top pistons, how much should i sink the exhausts (do i also need to sink the inlet?) would take it to minisport probably to get it machined properly.Also, if i did go the 940 route, do all the water holes match up to the 998 block?
#17 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 02 February 2010 - 01:08 PM
water holes all line up as do the oil galleries only problem is stopping the exhuast valve hitting the block / pistons
you can either sink the valves into the head or get the block pocketed
you then used a 1275 head gasket
#18 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 02 February 2010 - 03:07 PM
i bought keith calver's mini CD today which apparently covers in detail how to fit a 940 to a 998, so it looks like i will follow the guide and fit the 940, got the 202 on ebay now, probably get my money back for it :goaway:
just sourcing a 940 now, there arent too many but will bide my time, not paying over the odds for one on ebay
#19 spennyy2k
spennyy2k
  • 111 posts
  • Local Club: south lancs mini owners club
Posted 02 February 2010 - 04:55 PM
sink the valves 40 thou iirc... i think a 940 head will need skimming too tho to get the correct CR
#20 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 February 2010 - 06:27 PM
NO skimming - just sink the exhaust valves by 40 thou. Don't take it to the likes of Minisport - they will charge you a FORTUNE. Mine were done in 5 minutes - using a 45 degree countersink in a pillar drill.
#21 D1k1m4y
D1k1m4y
  • 217 posts
Posted 02 February 2010 - 06:34 PM
i think 140 is what it costs to get it all done including blocked channels gasket and fitting and stuff .
if you feel confident do it with the pillar drill, cheaper.
#22 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 02 February 2010 - 06:38 PM
would this do it bmc, because ive got a decent pillar drill at work
Visit My Website
