help
rattly-can
, Oct 27 2005 12:01 AM
24 replies to this topic
Posted 27 October 2005 - 12:01 AM
im new just joined got a baby blue 998cc clubby and jus wondering if theres any significant power gains with a turbo on a 998 unit. if so wer and how do i go about finding the parts required cheap as possible
thanx rattly-can
thanx rattly-can
Posted 27 October 2005 - 02:26 PM
you cant realy just bolt a turbo on a standard engine, you have to uprate most of the internals in the engine, buy a oil cooler, turbo modified carb, turbo oil pump etc etc the list goes on and on. the best thing to do is try and get a metro turbo engine complete, which you can chuck straight in the car.
Posted 27 October 2005 - 04:37 PM
December issue of mini world rollin road in the back... standard 1000cc with a cossie intercooler and modified cossie/metro turbo... 72 bhp but the clutch was slipping
it can be done.
it can be done.
Posted 27 October 2005 - 08:12 PM
Thats not the point. :cheese:Dont 1275 nonturbo put out this anyway?72 bhp
Its just pure grin factor
Think about telling the chav in his 1.6 Fiat Punto chavster that hes has just been left behind at the lights by a 1 litre Mini
The aim should be 100bhp per litre. Reliably achieveble with the big bore short stroke Cooper S970, either turbod or 16valved. but then you realy do need a big wallet and a very understanding bank manager :nugget:
Posted 27 October 2005 - 11:19 PM
many thanks people think i will go ahead with a turbo 998cc has any 1 got any diagrams for
1 moddifying the bulk head and
2 plubming the turbo to the block kind regards rattly-can
Posted 28 October 2005 - 07:08 AM
From the two questions above, I suggest that you maybe need to do a bit more reading about turbocharging.
www.turbo-mini.co.uk
and
www.turbominis.co.uk
Wouldn't be a bad place to start.
Wil
and
Wil
Posted 01 November 2005 - 12:34 AM
:nugget: i remembered while i was at work today that there was 998's (and probably others) that had a low c/r, i think it was about 8.5/9:1 you could run this with some boost, and the guy in the mag had an intercooler so it could mabe see 5-6psi of boost
i supose he could have used a 'standard 1 litre' Although personaly i would have strengthened the bottom end :gasp: .
Posted 01 November 2005 - 12:41 AM
just looked in the mag the guy was running 0.75 bar of boost ~ 11psi, i would have thought it a bit high for a standard 1 litre but if it works it must be ok right?
Posted 01 November 2005 - 08:19 AM
what mag are you on about brett?
Posted 01 November 2005 - 11:52 AM
if you dont mind doing a rebuild (which is DEFFO worth it for a highly-stressed engine like a turbo) Then you could always replace the standard 998 pistons with 1098 pistons, which are around 7mm shorter - which should give a silly-low CR for a nice raise of boost capability :wink:
12g295 head would be ideal as well, as they have massive chambers as standard, and nice flowing ports to aid power
Posted 01 November 2005 - 12:00 PM
To ask a silly question, is there any limit to how low you could get the compression ratio? I mean could you get the compression ratio down to something like 5:1 and run silly amounts of boost?
Posted 01 November 2005 - 12:39 PM
I guess you could get the CR down to 5:1 and run silly boost, but it'd be a bit pointless. The law of deminishing returns and all that.
With a CR of 7.5:1 you can easily run 20 PSI (maybe more).
Also a CR as low as 5:1 would make it a bugger to drive off boost.
Wil
Wil
Posted 01 November 2005 - 01:08 PM
Is this all on a standard bottom end?
Just using a different head to lower the compression?
Posted 01 November 2005 - 02:04 PM
Hmmmm, several turbos, always on boost....hang on....I'm getting an idea.......oh, already said it...
