Spluttering Mpi Under Acceleration
Posted 03 February 2010 - 12:33 PM
I have a 97 MPi cooper
Spec
1293CC Mpi Block
Stage 3 Head
1.5.1 Roller Rockers
K&N with 48mm Alloy Throttle Body
I have had my stage 3 head on teh car now for 3 months and the car has been running good. However in the last few weeks the car has been spluttering when accelerating. I was doing 40 on the motorway last night and when I was clear of teh road works I applied a little pressure to teh Gas pedal to increase my speed.
The car stated to splutter and then eventually corrected itself.
This has been happening a lot recently and wondered if anyone can shed any light?
Its almost like there is no petrol in the tank.... but its full
Mike
Posted 03 February 2010 - 02:12 PM
Posted 03 February 2010 - 02:15 PM
have you checked the lambda sensor?
check tat its connected or check that its not blocked???
It shows as value reading on teh ACR4 reader
Mike
Posted 03 February 2010 - 04:50 PM
You can either fit a PBV adjustable regulator or try and strip the relief valve (very carefully) and replace the o rings - it's not supposed to be a serviceable part but I reckon with a bit of care it can be?
I had similar problems with my MPi, see the following threads..............
Clicky 1 Clicky 2
Good Luck
Edited by nicksuth, 03 February 2010 - 04:51 PM.
Posted 03 February 2010 - 07:28 PM
On the ACR4 what are the values alternating between and how fast?
Terry
Edited by tmsmini, 03 February 2010 - 07:29 PM.
Posted 04 February 2010 - 08:59 AM
A basic check is when was the fuel filter last changed?
Terry
Cant remember the values of teh top of my head, but I will check tomorrw
The Fuel Filter was last changed less than a year ago when I built the car.
Mike
Posted 04 February 2010 - 10:11 AM
Fuel pressure I reckon, the o rings have probably perished and causing low pressure.
Clicky 1 Clicky 2
Good Luck
Cheers for that, I read the second Link you gave me, It had more info contained in there.
I have a spare set of injectors and also a spare fuel rail. I will try swapping these over at teh weekend and see if we get any sucess. I bought a spare Inlet manifold not long ago.
I will also check teh O rings on the rail and the Map Sensor.
I regularly get popping coming from the Throttle body when accelerating
Mike
Posted 07 February 2010 - 09:23 PM
Changed the oil, sparks and set the gaps.
I also stripped off the fuel pressure rail and the injectors.
I bought a spare complete manifold just before christmas that was removed from a 00 sportspack.
From this I used the fuel rail and pipes, and left my original injectors.
I also noticed that the fuel pressure valve had 3bar marked on the top of it. Not sure if this one is standard or uprated???
I took the car for a drive. It is slightly better. Seams to have more pull... but still has the spluttering around the 3-4000 rpm mark when on the motorway or in 2,3 or 4th when pulling away.
Any other suggestions apart from FSE adjustable pressure valve?
Mike
Posted 07 February 2010 - 11:49 PM
Posted 08 February 2010 - 08:19 AM
MAP sensor, or throttle position sensor.
I have both spare, so will try them when I get a free few hours
Mike
Posted 08 February 2010 - 10:45 PM
Posted 09 February 2010 - 10:32 PM
Tried the search facility but I think the info was buired in another thread?
Edited by nicksuth, 09 February 2010 - 10:37 PM.
Posted 09 February 2010 - 10:55 PM
Posted 10 February 2010 - 09:58 AM
I had similar symptoms with my mpi, after 12 months of trying all sorts of fixes it was finally cured by replacing the Fuel Pump Relay Part No YWB100970, plenty on Ebay as the same relay fitted to other Rover models including MGF, I think I paid about £5 for mine and its simply a straight swop over. Usual signs of a failed or failing relay are sign of burning around connectors on the relay, just pull to multi plug off and have look.
please forgive me for being dumb here
But the wiring diagram shows the fuel pump being connected to the inertia switch > engine compartment fusebox > the main relay pack in the engine bay.
Is this the fuel pump relay you are refering to????
or is it somewhere else?
Mike
Posted 10 February 2010 - 09:00 PM
