hi all can see a lot of you are making subframes up to fit your k sereis in standard round nose using mini suspension. so was just wondering if any of you had done any diagrams and meserments when mocking it up that you could post up or email me at bhpmini@googlemail.com as on a very tight budget and time frame so screw up need to be keep to a min lol
other tips welcomed like
r65 or r65u box?
1.8vvc or 1.8 with a hot cam?
will 12" wheel work well with the box ratio or best on 13"?
will a spi fuel pump cut it?
ANYTHIN ELSE YOU WISHED YOU HAD THE ANSWER TO BE FOR YOU STARTED YOUR K CONVERTION
IF YOU DON'T ASK YOU DON'T GET
K Subframes Tips/diagrames
johnflamered
, Feb 05 2010 08:47 PM
No replies to this topic
