Knocking Under Acceleration?
16 replies to this topic
#1 flanders56
flanders56
  • 320 posts
Posted 06 February 2010 - 09:49 AM
every now and again there is a knocking sound and feel under upon acceleration.. what could this be?
usually when changing gear by the way
#2 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 06 February 2010 - 09:51 AM
Sounds to me like it could be worn engine mounts/steadys, try rocking the engine backwards and forwards when parked and check for play
#3 Cooperman
  • 23,315 posts
Posted 06 February 2010 - 05:18 PM
It ould be one of several things, but make sure it's not too much advance on the ignition timing as if it is and it is knocking as a result of that, you will end up with broken piston rings and an expensive engine re-build.
However, it could be a drive shaft, an engine mounting or engine steady bush, an exhaust mounting or even a damaged gear-change linkage.
It's impossible to tell without seeing and driving it, I'm afraid.
#4 matt black
matt black
  • 47 posts
Posted 07 February 2010 - 08:42 AM
mine was doing the same
it was an exhaust U bolt hitting the underside of the car ,
but yours may be a different problem
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 February 2010 - 09:12 AM
also worth checking for cracks in the body around the subframe mounts and stabilizer mounts
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 February 2010 - 01:45 PM
Make sure this exhaust bracket is securely attached too: -
naughty: -
nice: -
#7 mini_adam
mini_adam
  • 198 posts
  • Local Club: fabmoc.co.uk
Posted 08 February 2010 - 10:44 AM
i had this..............
i had droped a door screw down the back off the subframe and it was traped between the subby and steering rack so when i accelerated or braked it knocked.
#8 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 08 February 2010 - 12:26 PM
Big question coming up;
Is it a single knock, or a knock-knock-knock-knock, etc, etc.
Also do you feel an impact through the pedals or floor?
Dave
#9 flanders56
flanders56
  • 320 posts
Posted 08 February 2010 - 04:16 PM
Dave
hi dave, yes i do feel impact through the pedals and sometimes it can go knock knock knock knock but been driving like it for a while so i know how to avoid it.. more gentle acceleration it seems. Bouncy roads seems to make it worst also
#10 tomsbluemini
tomsbluemini
    My Blue little monster
  • Area Managers
  • 1,498 posts
  • Local Club: LSMOC / Kentish
Posted 08 February 2010 - 05:05 PM
Sounds more likely to be engine mounts, but best to get it checked...
I had exactly this a short while ago with my MPi...
#11 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 09 February 2010 - 12:23 PM
As per PM, I'm with Tom, check engine mounts and steadies.
To check lower mounts you could put jack under the engine and push the sump up a bit, does the suspension go up, or the mount look like it's moving.
Top steady, check by grabbing top of engine and trying to rock back and forth, with handbrake on and on level ground.
Dave
#12 Carlzilla
Carlzilla
  • 1,907 posts
Posted 10 February 2010 - 03:17 PM
not a bad guess on my part then :thumbsup:
#13 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 10 February 2010 - 03:59 PM
Don't get carried away Carl - yet to be proven right...
#14 Carlzilla
Carlzilla
  • 1,907 posts
Posted 11 February 2010 - 09:19 AM
I know, i know :)
#15 martin24
martin24
  • 35 posts
Posted 11 February 2010 - 01:22 PM
Hi Guys,
I have a similar sort of problem to do with acceleration on my Rover mini italian job.
It seems that when i accelerate in gear 1, 2 or 3 i get a slight grinding noise before its time to change gear, it sounds like its coming from the drivers area, not to sure whether or not its outside in the engine area or inside around the 3 dials, its only really started doing it about 3 weeks now I've noticed.
Any ideas what it could be? as I'm baffled!!!
Martin.
