If your aspiring in the £600.00 region I'll do a deal with you
Thanks mate
I'll PM you shortly.
Right, just been down to take some photos....unfortunately its not
quite as rust free as I seem to remember, although it's
by no means rusty and the main rust-prone areas are fine. Sills are perfect, as are the valances, scuttle has very minor bubbling in the corner, and under the lights there are also tiny bits of bubbling. The floors, although there are no holes, could probably do with new floor pans on both sides at the front (the back is fine). The only other point of mention is that there is a very small hole in one corner of the battery box in the boot. The only other thing I forgot to mention was the state of the pieces of bodywork where the "sportspack" arches used to be. I say "sportspack" because they weren't sportspack...they were very badly made and installed fake sportspack arches which I have removed. The reason the bodywork looks the way it does it because they have attempted (again, very badly) to de-seam it with a lot of filler. For these areas, I have removed most of the filler and gone over the exposed areas with Hammerite primer. All that needs doing is it just needs to be smoothed back into the original bodywork and painted. Other than that, the car is fine.
Taken a load of photos which you can view here:
http://s30.photobuck.....unny/My Mini/The Password is: minimini
Ignore the tin on the floor of the interior....that's only there because I've taken the heater out to flush the matrix and so is just there incase any more coolant comes through the pipe. Also, the passenger seat is there, I've just taken it out so I've got a bit more space to work in there. The car also comes with a full set of brand new 'Special' Rover arches.
All in all, I think the car is still worth a good £600 as I reckon it would only take someone relatively experienced and who can weld less than £100 to get this car roadworthy again...which I'd love to see
Edited by The-Womble, 10 February 2010 - 02:57 PM.
