1990
This one give me quite an enigma. I've just bought an original accelerator cable for the HIF44 carb and fitted it to the Mini. For the first couple of days, it goes fine, the acceleration pedal action was smooth and all. But then, it started to feel a little bit hard to press the pedal like it was stuck somewhere, or dirt interfering with the cable action.
I dismantle the cable and found that there was no trouble at them, no frays, dirt or anything and when it's not connected it's smooth. I checked the carb connection, and the spring's smooth and no problem as well. The pedal, same condition, it's fine. Fitted it back, and it's smooth again. But, like before, a couple of days later it is difficult to press the pedal. It's gradually becoming harder to press.
But, if I wiggle or turn the plastic end housing or the casing itself, then it will be smooth again
I seriousy cannot find fault in the cable, casing, assembly, carb or pedal itself.
Does it mean I have to pour a little oil into the cable casing to smoothen the cable's operation?
I hope I make myself clear and understandable for you all...
Appreciate the answers you can give me...
