My Mini Is Stranded How Do I Get It Home?
#16
Posted 11 February 2010 - 05:19 PM
#17
Posted 11 February 2010 - 05:20 PM
#18
Edited by mk3 Cooper S, 11 February 2010 - 05:20 PM.
#19
Posted 11 February 2010 - 05:29 PM
#20
Posted 11 February 2010 - 05:35 PM
If it does turn out to be a burnt out valve... maybe worth posting a picture of said item when it's sorted...
#21
Posted 11 February 2010 - 05:38 PM
so if i attached it to the subframe it would end up damaging the front panel which ive only just had repaired
If you get an eye how/where would you fit it so it wont affect the front panel on tow?
Don't worry, the tow eye replaces the teardrop bolt, it doesn't touch any panel, its only held on the subframe
Not sure if you can see but there is a cut out hole on your front panel for this reason (well also so you can get to the teardrop bolt!) It wont touch any panel so hook up and your away.
Hth
#22
Posted 11 February 2010 - 11:00 PM
#23
Posted 11 February 2010 - 11:10 PM
http://mra-minis.co....7374db9394a2073
