Any Computer Wizards?
22 replies to this topic
#16 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 16 February 2010 - 09:05 PM
have you cleared your internet browsing history? if not, you may have god knows how many files you dont need there!
#17 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 16 February 2010 - 09:06 PM
Temp files! - I gained a whopping 14GB of space back when I cleared all that stuff out!
Also ... make sure you've emptied the recycle bin ... anything deleted won't actually delete until you clear that, too.
Tango ... As a side note, we're with a company called Avanti Communications for broadband. It's a form of satellite internet. We're too far from our exchange to get broadband in the normal way. It's not cheap, but it's quicker than dial up. You can get different speeds though, it's just how much you're prepared to pay.
Hope this helps :D
#18 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 16 February 2010 - 09:14 PM
Could you do a disk clean up?
#19 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 16 February 2010 - 09:39 PM
Try this neat little program (no install needed and it's only 1MB big), Temp File Cleaner. If it's realted to Windows and not a malware issue it will clear it. I recon it does a better job at clearing Windows files than CCleaner personally.
Only problem is that it requires Java but any well seasoned machine should have that. I'm doing a bit of Googling on the winsxs folder now for you.
Dave.
Edited by dsgoody, 16 February 2010 - 09:40 PM.
#20 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 February 2010 - 09:48 PM
right have a good read here Linkyand there is a little programe that will sort your problem out :D
#21 dsgoody
dsgoody
  • 519 posts
Posted 16 February 2010 - 09:50 PM
right have a good read here Linkyand there is a little programe that will sort your problem out :wub:
Bookmarked. After Googling it seems like I'm going to be needing something like this at some ponit in the furture. Good find :D
#22 .998TANGO.
.998TANGO.
  • 290 posts
Posted 16 February 2010 - 10:06 PM
woohoo!, free'd up enough to get ccleaner working which has free'd up an extra 200mb and downloading tempcleaner to see if it can free up some more,
then going to try winsxslite.
thanks for all the help guys its muchly appriciated :wub: :D
Elliot.
#23 Deev
Deev
  • 261 posts
Posted 17 February 2010 - 01:58 AM
Move your page file to the D drive - that should free you up a ton of space...
http://maximumpcguid...as-paging-file/
(It says on there not to move it to another partition but frankly I've done it myself many times and I've found it more often than not improves performance, not degrades it!)
