2 To 3 Clocks?
6 replies to this topic
#1 dougal72
dougal72
  • 32 posts
Posted 23 February 2010 - 08:17 PM
Hi all, i've got myself a set of 3 clocks to replace my 2, and also a nice dash too. My question is will i need any new brackets to hold the clocks in place? My mini is my daily drive so i'd like to know i have all the bits i need to fit the new before i rip out the old!
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 23 February 2010 - 08:22 PM
If the clocks attach to the rear of the new dash, then you should be fine.
If they don't, then you'll be needing the triple clock cage mount.
#3 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 23 February 2010 - 08:25 PM
if i remember right if the clocks bolt to your dashoard you will have to remove the original bracket, then the dash just clamps to the top and bottom dash rails. You may have i wire with a bullet style connector on it which is what you connect to the rev counter. im sure someone will be on here soon that can tell you in more detail than me if needed
#4 Kam
Kam
    Straight to the Point
  • 4,144 posts
  • Local Club: 16vMini club
Posted 24 February 2010 - 01:48 AM
If your replacing your nippon 2 clocks with the same 3 clocks then as taffy said, your current 2 clock is held by a bracket, so if your getting a 3 clock then you will need the 3 clock bracket, the same also with the plastic binnacle shroud
However when you buy a new dash you just screw (small screws!) your nippon clocks straight to the new dash. So then you can just remove the brackets as they are not needed.
The bolts for these brackets are in the engine bay bulkhead
This link might help a bit for the rev counter wires, scroll to the bottom Clicky
Wont take long to do so shouldn't be a problem, just make sure you got some new brackets (different brackets to above) for fitting your new dash to the dashrail like clivemk1mini said, also you will need to swap your mileage dials over, again no biggie, I can post up pictures on this if your not sure though, you may have a bit of trouble removing the speedo cable plastic plug from the back of the dash, can be awkward sometimes.
If you can post up any pictures of what you got there then we can tell what you need, if anything?
Hth
#5 dougal72
dougal72
  • 32 posts
Posted 24 February 2010 - 07:58 AM
Excellent, thanks for the pictures, they tell a thousand words! My new clocks and dash should be arriving this week ( also bought a matching centre console, but don't tell the wife!) so i'll get some before and after pictures posted up.
Thanks again for sharing your knowledge!
#6 mymini007
mymini007
  • 2,046 posts
Posted 24 February 2010 - 08:23 AM
You will have to trim the indicator tunnels too, as the clocks wont sit flush against the dash.
#7 jameslearwood
jameslearwood
  • 525 posts
  • Local Club: ALL ALONE
Posted 25 February 2010 - 04:00 PM
Ive just fitted a new dash but still have two clocks where did you get your 3 clocks from
