Overheating
6 replies to this topic
#1 minimepls
minimepls
  • 16 posts
Posted 10 March 2010 - 12:36 PM
hi guys, just a quick question, i have just fitted a 998cc replacement engine for my last 998 engine, only the engine i have just replaced it with seems to overheat when im on the motorway its never gone all the way to the HOT but it does go half way between the medium and the hot, this only happens when im goin up hill in the mini or im on the motorway, on local roads i can drive all day non stop and i dont ever see any overheating at all, any advice is appreciated thanks in advance
#2 minidino
minidino
  • 116 posts
  • Local Club: phoenix moc
Posted 10 March 2010 - 01:23 PM
hi mate on the face of it,it sounds to me like its just the engine doing more work on motorways and hills which is causeing the up in temp but bear in mind the following:-the condition of the water in the cooling system is it clean and does it have adiquet antifreeze content as this helps to keep the engine cool,how old is the thermostate is it opening fully at the right temp?,is the waterpump in good condition? is the rad clear not blocked or damaged?is the cooling fan in good condition and no blades missing?is the temp gauge acually reading correctly? these are all things to take into consideration when facing an overheating problem also if the gauge is not actually reading into the red it proberbly isnt overheating hope this helps you out.
#3 jaydee
jaydee
  • 8,565 posts
Posted 10 March 2010 - 01:40 PM
Remove radiator and flush it with clear water, then flush the system with the heater on till you see clear water coming out the hose.
Refit the radiator and fill the system with water and a 30% of coolant, make sure its glycol-ethilene based.
#4 minimepls
minimepls
  • 16 posts
Posted 10 March 2010 - 01:54 PM
great i am just gonna remove the radiator hose now and bleed the water, the guy who fitted the engine said he did not put any antifreeze in it at the time, of refitting the engine, he just put water in there!!! so im gonna take all the water out and put some propa glycol ethilene based coolant in thanks alot il let you know how it goes cheers
thanks alot minidino too il make sure i check the rest of the variables that you have highlighted il get the haines manual out ;-)
#5 jaydee
jaydee
  • 8,565 posts
Posted 10 March 2010 - 02:02 PM
Thats probably the cause of your problem, definately mix water with a good 30% of coolant, it helps against either freezing and overheating.
Removing the rad its actually easier than stated on the hynes, remove the plate which connects to the thermostat, remove the retaining bolt under the rad and remove top hose and bottom hose from the water pump. To refit hoses, smear a little grease for an easier fitment.
Edited by jaydee, 10 March 2010 - 02:03 PM.
#6 minidino
minidino
  • 116 posts
Posted 10 March 2010 - 06:55 PM
i would not use grease when fitting rubber hoses as this could limit the life of the hose plus not only will the hose go on easy it may pop off during use even with the clip done up if you must use lubricent to fitt hoses use something like washing up liquid that will fade with time.
#7 minimepls
minimepls
  • 16 posts
Posted 10 March 2010 - 09:34 PM
thankyou to you both for your advise
