Oil Leak, Help!
2 replies to this topic
#1 ROXTEE
ROXTEE
  • 26 posts
Posted 10 March 2010 - 01:34 PM
Hi guys,
May I seek help from you?
There is an oil leak quite obvious, even park for 30 minutes, there are few oil drop. The leak is from the area that the gear select shaft linked to the bottom at the back of gearbox.
The exact location is: where the linkage get into the gearbox, further to the gearbox about 1-1.5 centre meter there is a bottom half O shape on the bottom of gearbox with black seal, the oil is leaked from there.
May I ask what type/the name of seal is that one? any seal and any thing else do i need to get it changed? And how hard/ how to change it by myself?
Thanks for you help.
Regards
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 10 March 2010 - 01:38 PM
http://www.minispare...p;title=GEARBOX ROD CHANGE ANTI O...
Thats the seal
Hardest part is knocking the roll pin out of the sleeve so you can get the rod out of the road to remove the old seal.
#3 biggles1293
biggles1293
  • 167 posts
Posted 10 March 2010 - 02:39 PM
Thats the seal
As above, common leak ive found, done it on both my minis!
