Heater Issues !
33 replies to this topic
#1 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 10 March 2010 - 05:00 PM
is it just me or are the heaters in mini's absolutely JUNK ! :)
they should be called coolers rather than heaters
or could there just be a problem withy my heater. i have bought and fitted a new matrix and still no difference. i have also unblocked the pipes and still no change.
so my only solution is that they are just crap heaters.
#2 Pooky
Pooky
  • 5,691 posts
Posted 10 March 2010 - 05:11 PM
Mine's brilliant :)
What sort of bypass do you have on your mini and what degree rating is your thermostat?
#3 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 10 March 2010 - 07:16 PM
Mine's brilliant :)
whats a bypass ?
do i find the degree rating on the dials ?
#4 harryh733
harryh733
  • 220 posts
Posted 10 March 2010 - 07:41 PM
I changed my thermostat for an 88 degree one and since then its been much better! it actually throws out hot air now! :)
#5 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 10 March 2010 - 07:58 PM
is that easy to do ( changing thermostat ) ?
#6 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 10 March 2010 - 08:08 PM
just bought an 88 degree thermostat there. fingers crossed i will be nice and warm once fitted :)
#7 harryh733
harryh733
  • 220 posts
Posted 10 March 2010 - 11:41 PM
They are a nice easy thing to change. I got another thermostat housing gasket too as mine fell apart when I took it off (they are really cheap)
if you need any help let me know but should be pretty simple :thumbsup:
#8 Boycie
Boycie
  • 1,978 posts
Posted 11 March 2010 - 06:55 AM
A new matrix should make it proper toasty inside!! My heater is brill.
Are both pipes going to and from the heater hot? If not, you still have air in the system :thumbsup:
#9 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 11 March 2010 - 10:00 AM
no they always feel cold. even after a run about. how to i get air out the system ?
#10 Boycie
Boycie
  • 1,978 posts
Posted 11 March 2010 - 10:09 AM
Oh ok, that's your problem then. To bleed the system you need to hold the various heater hoses in the engine bay below the level of the water in the top of the rad.
Run the engine at fast idle, with the rad cap off and the heater knob in the hot position. make sure the hoses are below the rad level and keep topping the coolant up until you start getting hot hoses to and from the heater. Replace the cap, go for a drive and check the coolant level when you return (and after it's cooled down for safety).
Top it up again and you should be bled through properly :thumbsup:
#11 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 11 March 2010 - 10:33 AM
Top it up again and you should be bled through properly :)
nice one, will give that a shot.. thanks so much :thumbsup:
#12 jacksmags
jacksmags
  • 115 posts
  • Local Club: BMC
My heater used to be warm but now it just leaks warm into my car!
Why do you think this is happening? :thumbsup:
#13 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 11 March 2010 - 11:25 AM
This might sound daft, but are you sure the valve which controls the water flow to the heater is working? The one you adjust with the heater cable in the car.
#14 jacksmags
jacksmags
  • 115 posts
  • Local Club: BMC
Posted 11 March 2010 - 11:33 AM
I have recently replaced it but it would easily have broken yes! :thumbsup: Thanks
Ill check it now!
#15 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 March 2010 - 11:40 AM
Have you checked the Heater Matrix? Might just have split the pipe or could need a new matrix.
