Learning To Weld
27 replies to this topic
#16 Punts
Punts
  • 137 posts
Posted 10 March 2010 - 09:22 PM
That's a good effort if it's your first time. As has been said before it's all practice. Experiment a bit with different heat settings and wire speeds, when you find one that gives you a good result, write it down, it'll be a good starting point for another day. :)
#17 Kam
Kam
    Straight to the Point
  • 4,144 posts
  • Local Club: 16vMini club
Posted 10 March 2010 - 09:27 PM
um i was mostly doing 90 degrees but occasionally i forgot and did 45s instead :)
I think your putting too much pressure on yourself? Theres alot to take in when trying it out for the first time so I think you've done well
All the other factors just take time and practise :)
#18 Boycie
Boycie
  • 1,978 posts
Posted 10 March 2010 - 10:12 PM
To be honest, I've never found the angle of the torch makes that much difference, even though people always go on about it!
More important is a nicely shaped weld, with little or no porusity (sp) that is not just sitting on top of the metal and has penetrated nicely through to the other side.
Remember, pretty much your biggest challenge with thin body panels in getting the least amount of warping as possible. The technique Michael expalined is what I use for non load-bearing jobs, like outer wheelarch repairs.
#19 trafficface09
trafficface09
  • 757 posts
  • Local Club: not yet but soon
Posted 10 March 2010 - 10:19 PM
cind of like how you staple a canvas to the back of a 2x2
how about when it gets a bit tighter? does anyone find it hard to get the ark between existing weld
curious though about thoes mrk 1 conversion rear light panels how do i get the straight? spirit buble?
and where the hell can i earth it?
#20 davidv
davidv
    Flowers of JOY.
  • 416 posts
Posted 10 March 2010 - 11:07 PM
Yes it is a good go.Every one will soon want you De-Seaming Minis but not yet.
#21 Kam
Kam
  • 4,144 posts
Posted 10 March 2010 - 11:10 PM
Whatever your welding to just hook up the clamp to your workpiece, just make sure its bare metal where it gets clamped. I even tried hooking it to a piece of sheet metal that was placed on the workpiece as the workpiece was quite small, still worked :thumbsup:
#22 trafficface09
trafficface09
  • 757 posts
Posted 10 March 2010 - 11:55 PM
water conducts electricity right? earth it to that ahaha :thumbsup:
anyway i was going to ask. i have had rather sensitive eyes after welding. still do, i had my mask on at all times. apart from when my friend was welding. i looked away at all times.
feels like eye strain/ headache do i have arc eye?
i hope so it sounds awsome!
Edit: poor spelling
Edited by trafficface09, 10 March 2010 - 11:57 PM.
#23 davidv
davidv
    Flowers of JOY.
  • 416 posts
Posted 11 March 2010 - 12:02 AM
Hope not if it is it feals like sand in the eye and do not rub.Get some squirt of the doctors..We want you on soldering jobs.You have seen the light,all the best mate.
#24 trafficface09
trafficface09
  • 757 posts
Posted 11 March 2010 - 12:18 AM
i dono, a bit like sand, but its not extremely painful. i doesn't hurt its just slightly uncomfortable, i think i may have got exposure of a white wall.
doctors closed
oh i think it may be time to join a Southwest mini club and meet up. one with a garage.
i can offer my services as a welder and fibreglass dude.
maybe they can help me with my hatchback conversion idea :thumbsup:
Edited by trafficface09, 11 March 2010 - 12:18 AM.
#25 Kam
Kam
  • 4,144 posts
Posted 11 March 2010 - 12:21 AM
What mask are you using? I ditched the hand held jobbie and got a full mask with auto tint so I dont have to bother dropping the helmet. It auto tints on arc.
If your full face mask does have a setting on the side it could be that? Notch it up
#26 trafficface09
trafficface09
  • 757 posts
Posted 11 March 2010 - 12:36 AM
i had the settings, it on medium low
#27 trafficface09
trafficface09
  • 757 posts
Posted 12 March 2010 - 01:40 PM
things are on the up, i am fabricating some square shrouds to fit into my grill for my raydot fogs, i did several consitently average welds with good penitration and no misses. my eyes still feel slightly strained but the higher settings helped on the mask >_<
that is all thanks
#28 davidv
davidv
    Flowers of JOY.
  • 416 posts
Posted 12 March 2010 - 02:24 PM
All the Welders will advise care for the eyes is no.1.
You can buy a top solution to fix a light burn from the Optitions.Its made for contact wearers and sorts out small eye problems only but safe.Costs a few pounds.You could also use buffered Saline.
