The only sure way method to tell is a bore gauge across the two axes.............
As for lock tabs, they are no longer used within the auto industry because of reliability issues, a stud locking compound is the preferred method.
Posted 16 March 2010 - 09:33 AM
Posted 16 March 2010 - 11:39 AM
Posted 16 March 2010 - 11:52 AM
Edited by Guess-Works.com, 16 March 2010 - 11:53 AM.
Posted 16 March 2010 - 07:49 PM
Hi,
Im currently overhauling my engine which ive removed from my mini.
I need to replace the gasket that fits between the gearbox differential housing and gearbox sump. I spoke to a friend who told me this is pretty simple, bend back the metal clips locking the bolts in place and simply take it off. He told me there was a spring and ball bearing that may pop out, and this is to do with oil pressure relief or something????
Anyway...can anyone give me any pointers. Currently my engine and block are out of my mini and the block is bolted to the gearbox. I dont plan to speerate the two.
thanks
Edited by Kerrin, 16 March 2010 - 07:57 PM.
Posted 07 July 2010 - 08:08 PM
Posted 08 July 2010 - 07:34 AM
Posted 08 July 2010 - 07:53 AM
Posted 09 July 2010 - 01:38 AM
also can I get the diff cover back off to clean it up and re seal with the engine in the car? or is it engine back out time?
Posted 09 July 2010 - 07:12 AM
Posted 09 July 2010 - 08:54 AM
Hi Grahama.Hi,
I have been following this thread as Iam stripping mine down as part of an overall rebuild. I have an 83 998 and gearbox and dif is seperate. How do you tell which type, (gasket/no gasket), you have??
Also Kerrin, would ove to see some pictures of the areas you are talking about, seals, gaskets etc.
Thanks,
Graham
Posted 09 July 2010 - 02:40 PM
Posted 09 July 2010 - 06:42 PM
Posted 09 July 2010 - 08:28 PM
