Vauvhaull 2.0 16v Not Red Top
secondopsman
, Mar 18 2010 06:50 PM
8 replies to this topic
Posted 18 March 2010 - 06:50 PM
Hi been offered the chance to buy 2.0 vauxhall conversion.seems to be the all speed subframe and engine mounts and the 2.0 16v (NON red top engine) engine is in the mini however ther are no carbs or altenator and although the engine was from a reputable vauxhall breakers it hasnt run in the mini.gearbox and driveshfts are there gearbox is fitted in the car but the drive shafts have not been altered.
Also i would be swapping this for my Mg metro 1275 engine thats in the car and running just had a strip and check over new rings bearings ect bores were excellant.had all the valves reground.so this would be up for sale to.
If anyone can guestimate what there worth or needs any more info to have a go these ask.
Thanks in advance
Pete
Thanks in advance
Pete
Posted 18 March 2010 - 07:32 PM
Don't know how much it's worth, but I would take the vaux' engine out of the equation, what you are buying is the frame, and is your engine worth ( and I assume cash ) the cost of the frame, I would also double check that it's an allspeed frame and not a home made jobbie. you still have to sort the drive shafts and potentially find parts for the engine.
Posted 18 March 2010 - 08:29 PM
I would say yes and get yourself over onto 16vminiclub. mark out the driveshafts to the lengths you need and get them chopped and rejoined or 'Aband' can make you some custom ones at a very good cost. Also like person above has said, make sure it's an allspeed frame. Also if you can afford it go TB's and megasquirt
Edit* Also 'Aband' also makes alternator brackets.
Edited by G-baby158, 18 March 2010 - 08:31 PM.
Posted 18 March 2010 - 08:36 PM
I going to check out the 16v forum instead of working tomorrow Must be honest im not up on all the 16v info i was under the impression that r1 carbs would be needed but i dont know alot regarding the ignition side of things.
Pete
Pete
Posted 18 March 2010 - 08:46 PM
You will also need a 90mm extended front. definitely go and have a look/post up on there. People on there are so helpful and out of the lot of them know everything lol.I going to check out the 16v forum instead of working tomorrow Must be honest im not up on all the 16v info i was under the impression that r1 carbs would be needed but i dont know alot regarding the ignition side of things.
Pete
Posted 18 March 2010 - 09:15 PM
I'd be interested in a frame if you deciede to pass on it.
As stated with a round nose you need to extend the front bodywork.
Posted 18 March 2010 - 09:25 PM
My plans are to put it in the mini i have its a mini 30 that now has a clubby flip front so this engine will be for sale hence the valuation on it.
Edited by secondopsman, 18 March 2010 - 09:34 PM.
Posted 18 March 2010 - 09:28 PM
I am looking to do the same but wanted to fit a K series
Posted 18 March 2010 - 09:35 PM
You won't need a extended front then mate so thats a plus side.
