Ballast Coil Or Not?
38 replies to this topic
#31 ste88
ste88
  • 258 posts
  • Local Club: LCMOC
Posted 27 March 2010 - 06:32 PM
if you've found the wires behind the dash isn't one of those 12v switched live and the other -ve side of the coil? if so then then 12v should be fine for the power shouldn't it? it should be 12v
#32 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 27 March 2010 - 07:28 PM
as i said previously, the green/orange cable is NOT off the coil, and is in fact a 12v switched live, that loops off the wiper motor, so you can use that cable to save yourself a LOT of bother :P
#33 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 28 March 2010 - 08:37 AM
as i said previously, the green/orange cable is NOT off the coil, and is in fact a 12v switched live, that loops off the wiper motor, so you can use that cable to save yourself a LOT of bother :)
sorry yea do remember you sayin that now lol think i got wiring on the brain to much trying to wire all this stuff in lol, im dreaming + and - all nite lol
#34 Carlzilla
Carlzilla
  • 1,907 posts
Posted 28 March 2010 - 09:53 AM
haha, i know what you mean, when i had my loom out for tidying and repair, it kinda got stuck in my head :)
#35 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 28 March 2010 - 06:48 PM
yea seeing wires of all colours lol, i have it all wired in now! rev counter worked just need to find a white wire for illumenation, and find somewhere to mount it! 12v socket in also need to find somewhere to mount lol, and wired on high level rear brake light works well!
#36 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 March 2010 - 08:37 PM
Not white for illumination. You need to find a red/green wire for the lights.
#37 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 28 March 2010 - 10:18 PM
Thanks would there be any i can use from the 4 fuse box on the bulk head? Im not havin to much luck finding many other cables, seems to be some behind switches but couldnt get of heater controls
or switches doh!
#38 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 March 2010 - 10:41 PM
Yes, fuse #4 is for the sidelight circuit and has red/green wiring. Connect to the fused side of it, not the supply side. Check on your lighting switch while the lights are on for the next few weeks to make sure it's not heating up, or if you have a suitable meter check the switch current is less than 16A with all the lights on. It's easy to overload the switch.
#39 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 29 March 2010 - 07:24 AM
great stuff looking from front of the box is fuse 4 the bottom one? and i think the fused side is the right side? i guess there is double spades on each side to add multiple things?
but not to many as things will overload!
I would hope the rev counter wont take to much power as its got a tiny bulb in it i think!
