Hey
I would love a set of your drilled Ti washers for the rear subby, any idea when your going to have them? also, would they fit as manifold washers?
Ben
I asked the engineer about the cross drilled rear subframe washers and they're going to be a bit expensive I think, probably a tenner each, but much cheaper if I don't have them cross drilled.
The cross drilled washers are expensive because a bloke has to turn the part round 60 degrees then drill and chamfer each hole. But, they do look really nice and they're a part you can see from the outside of the car and will be exposed to road salt so it's a perfect part to have in titanium.
I bought a 1 metre bar of 35mm and it was £120!
But now I've taken the plunge and bought it, I think I will convert half of the bar to washers. I'm thinking 50 plain washers and 50 cross drilled washers.
I don't think they'll be ideal for manifold washers as they're really wide, and the centre hole is wide, but I sell the 1 inch wide manifold washers (2.5mm thick)
Cheers,
rich
