I am putting the engine in my SPI back together (finally) and had this question.
I recently got into powder coating and will be doing all the brackets and such on the car. One I did was the front plate as they are always rusty messes. I recently installed my new SW5 cam and then test fitted the front plate, cam plate, and gasket. Is the cam supposed to right up against the cam plate? I can pull on the cam and it moves back a forth a bit. I dont have a dial gauge to give exacts. What is allowed for these? Should the front plate always be left bare and never coated/painted?
Cam Shaft End Float
brivinci
, Mar 29 2010 03:53 PM
1 reply to this topic
