Hi Everyone
I have a 1996 rover mini sprite 1.3 spi injection.
The problem i have is It keeps stalling at low revs... Today i changed the head gasket and valve stem seals to stop the smoking problem i had. Once i finished this i started it up and it ran like a dream.took it for a drive round the block and it ran really well untill i got home and it stalled.So i started it again and let it idle over for a few minutes and it then stalled again. So i left it for a few hours and then took it out again and when i slowed town in traffic it stalled again.Had to wait a couple of minutes before i could start it back up again.
Has anyone got any ideas on this problem and could you please point me in the right direction to fix it.
thanks
Spi Keeps Stalling At Low Revs? Help
diggy
, Apr 01 2010 03:37 PM
4 replies to this topic
Posted 01 April 2010 - 03:37 PM
Posted 01 April 2010 - 04:13 PM
Sounds like a vacuum leak, check all the pipes are connected and none have splits in them.
Posted 01 April 2010 - 04:30 PM
just checked the pipes and noticed a split on one of the pipes that connects to the carb.Would this do it?
Posted 01 April 2010 - 04:33 PM
yep that would do it but if replacing it doesnt work, i have problems like that from the coil.
Give it a good run though once you replace the pipe, just to let the ecu clear its head
ps, just for future reference when asking for help. An spi has a throttle body, not a carb.
Edited by Darkscamp, 01 April 2010 - 04:35 PM.
Posted 01 April 2010 - 04:54 PM
Cheers for the heads up on the throttle body...not carb,yep that would do it but if replacing it doesnt work, i have problems like that from the coil.
i'll order a new pipe and my mate is picking a new coil up at malvern mini show this weekend for me and i'll let you know how it goes.
cheers for you help R1minimagic and Darkscamp.
