Titanium Engine Steadies
36 replies to this topic
#1 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 10 April 2010 - 09:29 PM
Here we go then folks :)
I've started producing some Grade 5 Titanium engine steadies, to replace the standard item on the RHS of the engine. These could also be used as lower gearbox steadies if used with the correct brackets.
They use high quality bronze/teflon liner rose joints for smooth operation and fit, 2 stainless locking nuts, and 4 aluminium spacers. They weigh in at about 136g each, which saves over 210g compared to the standard item, and are adjustable from 165-180mm. Standard lengths are 161 and 170mm between centers. Custom lengths can be made up to 40mm longer. Please bare in mind that no machines were used to produce these, they are all hand made, so quality varies slightly between each one.
These come in at £25 posted to the UK, on a made to order basis, due to the cost of the materials involved.
#2 tomsbluemini
tomsbluemini
    My Blue little monster
  • Area Managers
  • 1,498 posts
  • Local Club: LSMOC / Kentish
Posted 10 April 2010 - 10:59 PM
These look great!
I'd be interested in using these as steadies for down at the gearbox end. Are you able to provide the brackets aswell? I've been told that my MPi needs these but i'm dumb and don't know what brackets to get :)
#3 HARBER07
HARBER07
  • 4,498 posts
Posted 10 April 2010 - 11:07 PM
to be honest I have no idea either! I may be able to make up some brackets in stainless or something, but I would have no idea what they are supposed to look like on an MPI :). My 998 had one of THESE. fitted if that helps?
#4 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 10 April 2010 - 11:09 PM
to be honest I have no idea either! I may be able to make up some brackets in stainless or something, but I would have no idea what they are supposed to look like on an MPI :). My 998 had one of THESE.. fitted if that helps?
Haven't got a clue - I'm sure some bright spark will know :D
#5 HARBER07
HARBER07
  • 4,498 posts
Posted 10 April 2010 - 11:19 PM
The brackets seem to be relatively cheap either way. Sorry I can't help finding the right ones though, I'm not too clued up on Injection minis :)
#6 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 11 April 2010 - 08:55 AM
So they don't need bushes?
#7 CobraV8
CobraV8
  • 991 posts
Posted 11 April 2010 - 08:59 AM
Looks nice, but surely the vibrations will come straight through these into the car - it will effectively be solid mounted.
#8 HARBER07
HARBER07
  • 4,498 posts
Posted 11 April 2010 - 09:03 AM
Nope, no bushes needed Monkey :) . And yes, it will effectively be solid mounted. The primary use for these was to save weight. I didn't feel a lot of difference vibrations wise, from a poly bushed standard steady.
#9 HARBER07
HARBER07
  • 4,498 posts
Posted 19 April 2010 - 07:45 PM
Still got some.
#10 puresmartie
puresmartie
  • 188 posts
Posted 19 April 2010 - 07:50 PM
do you supply little rubber boots to go over the rose joints? to stop the grit and *poop poop* getting in them....
#11 HARBER07
HARBER07
  • 4,498 posts
Posted 19 April 2010 - 07:56 PM
Nope, unfortunately not. Didn't see the need for them, as the amount of movement in the rose joints will be next to none.
#12 samsfern
samsfern
  • 5,243 posts
Posted 19 April 2010 - 08:03 PM
i get paid on the 30th, so will defo have one off you then, im getting tired of constantly changing the bushes!
#13 01smartc
01smartc
  • 1,412 posts
Posted 19 April 2010 - 08:06 PM
Might been needing some custom ones made up in the next few weeks if thats somthing you could do?
Chris
#14 HARBER07
HARBER07
  • 4,498 posts
Posted 19 April 2010 - 08:07 PM
:wub: No worries. Only ever had to change the bushes once, and that was a PITA :thumbsup:
#15 HARBER07
HARBER07
  • 4,498 posts
Posted 19 April 2010 - 08:09 PM
Chris
Yeah definitely :thumbsup: . PM me the details whenever.
