Trying To Retreive Original Identity For My Mk3 Shell....
Posted 11 April 2010 - 10:39 PM
it is a twin bolt subframe, drip rails on roof gutters, small petrol tank, non opening rear windows, single piece roof lining inc c posts, the colour is, or at least was, blaze orange and it has the later style gearchange exhaust tunnel, few people have told me its around a 74.
can i get anything from the commision plate to point me closer to getting the chassis number etc?
thanks
scott
Posted 11 April 2010 - 10:42 PM
Posted 11 April 2010 - 10:45 PM
scott
Posted 11 April 2010 - 10:57 PM
Posted 11 April 2010 - 11:00 PM
thanks
scott
Posted 11 April 2010 - 11:18 PM
Posted 12 April 2010 - 06:56 AM
Posted 12 April 2010 - 08:51 AM
With a little bit of luck Heritage MAY be able to ascertain the identity of the vehicle from the commission number but not always, ideally they prefer to have the chassis number.
Posted 12 April 2010 - 09:54 AM
Also, if it's rod change it won't have the little ashtrays in the rear pockets
Check out the bulkhead crossmember in the engine bay. If the depression for the carb jet is shallow, the shell was produced before late '75/early '76 (8-10 months before the single-bolt crossmembers came out to accomodate the 'rubber' subframe). Early 1976 to late '76 had the twin-bolt frame as before but a deep depression in the crossmember to allow for the newly introduced waxstat carb jet.
The smaller 5.5 gallon fuel tank stayed all the way up to 1975/early '76 - my late '75 has one.
Also, the paint may not be Blaze (red) or Vermillion (orange) as there were quite a few similar shades around in the early 70s, for example 'Flamenco' on my car (see sig).
Incidentally, when I was working on ine yesterday I noticed another date stamp.. this time on the mechanism that the interior door handle operates- I'll get a picture for you
Edited by Boycie, 12 April 2010 - 09:54 AM.
Posted 12 April 2010 - 10:16 AM
Posted 12 April 2010 - 11:22 AM
Posted 12 April 2010 - 11:26 AM
Posted 12 April 2010 - 11:27 AM
Posted 12 April 2010 - 11:44 AM
From the good old points scheme, you need not only the original shell, but two other major components from the original vehicle, be it Suspension, Steering, engine or box...
Suspension, Steering, engine or box... all these wear out and are likely to have been changed over the life of this Mini so how does either side prove these components are original, carbon dating perhaps?
Posted 12 April 2010 - 11:47 AM
