Diy Cone Compression Tool
Posted 13 April 2010 - 08:07 PM
can i get a threded bar and weld a leverage handle on-top?
Posted 13 April 2010 - 09:11 PM
Posted 13 April 2010 - 09:28 PM
I am 90% sure it was 1/2 "UNF . Mine is 14mm std pitch
Make that 100%
http://www.minispares.com/Search.aspx
And if you fancy a read
http://savetheminis....one-compressor/
Hth
Posted 13 April 2010 - 09:42 PM
Posted 13 April 2010 - 10:09 PM
Do not put your fingers anywhere you wouldn't put your............ well hopefully you get my drift here it really can be a dangerous job if not done correctly.... and if you think it won't happen to you ? then go and have a look in the local casualty department.
Posted 14 April 2010 - 12:58 AM
In addition to which I will add that if you shop around you will find different grades of steel used for the threaded rod. Buy the material with the highest tensile strength, not the cheapest material. Buy several nuts for the rod at the same time. Rather than weld a T handle to the rod, fit two nuts to the "top" of the threaded rod and one mid-length. Jam the two nuts at the top together and turn the lower jam nut with a long wrench. You'll have more leverage than the T handle and you will be more to the side instead of "over" the assembly.
It is unlikely you will want to put the old cones back in so buy a length of the 14mm rod (and nuts) at the same time (along with new cones). When taking the old cones out, make life easier and safer for you. Make sure the threaded rod (and washers) are well lubricated and start compressing the cone while the car is still standing on its wheels. After you have applied a bit of tension, stop and jack the car up. The weight of the car will have assisted you a bit with compressing the old cone.
Posted 14 April 2010 - 05:48 AM
dave
Posted 14 April 2010 - 06:16 AM
Edited by robtheplod, 14 April 2010 - 06:17 AM.
Posted 14 April 2010 - 06:24 AM
Posted 14 April 2010 - 10:30 AM
Posted 15 April 2010 - 04:03 PM
ok so i think i better revise the procedure alot before i start, sounds like the most dangerous thing i will have to do.
i will probably look through the Haynes manual but just so i know, once the cone is compressed is it safe to remove, and how do i put the new high-low trumpet in
anyway thanks all
Posted 15 April 2010 - 04:14 PM
I'm sure Sticky will give you the low down when you get your hands on his tool, but don't lubricate the end before inserting it!
Posted 15 April 2010 - 04:26 PM
Posted 15 April 2010 - 06:31 PM
Posted 15 April 2010 - 11:10 PM
