Diy Cone Compression Tool
19 replies to this topic
#16 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 April 2010 - 01:53 AM
You're tarp as a shack?
If you have access to the professional tool then by all means borrow and use it. However, if you ever do have to make your own, just make sure you look for the higher-grade steel for the threaded drawbar. I wish I could tell you the grade I used but my experience is that your material numbering system and that used in the U.S. are very different.
Good luck and let us know how it turns out.
#17 buxvan
buxvan
  • 146 posts
Posted 16 April 2010 - 09:39 AM
i don't know why you need a cone compressor. i have always been able to remove & refit the suspension components without one. using a big screwdriver as a lever. it's not a bodge either.
hope you manage to sort it.
#18 MRA
MRA
  • 7,607 posts
Posted 16 April 2010 - 09:47 AM
We would be interested to hear about your method.
#19 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 April 2010 - 12:16 PM
Fitting new cones with a screwdriver... or re-fitting the old cones you took out? Using Hi-Los or normal trumpets?
#20 trafficface09
trafficface09
  • 757 posts
  • Local Club: not yet but soon
Posted 16 April 2010 - 04:17 PM
it think buxvan is talking about the rears, im talking about the front trumpets that sit in the front subframe, they are commonly replace for high lows :P
