Rustoleum
32 replies to this topic
#1 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 14 April 2010 - 09:20 AM
Hi
just a few quick questions about rustoleum, how well is it at hiding surface blemishes? ill be painting the car black and know how apparently black shows up blemishes very easily so was thinking if its a touch thicker than spraying it may hide small problems i have in my paint work.
also where do you get it from and what type of rustoleum do you get? are they suitable to do say metal car body pannels and also fibreglass front end pannels?
and also if it is suitable for both types of pannels what should i do to prep the FG pannels before rollering?
Dave
Edited by mini93, 14 April 2010 - 09:20 AM.
#2 cherryblossom
cherryblossom
  • 450 posts
  • Local Club: medievil minis
Posted 14 April 2010 - 09:27 AM
nothing.... lol
#3 luiji89
luiji89
  • 1,039 posts
Posted 14 April 2010 - 09:42 AM
not too sure on how to prep the fiberglass sorry...
the rustoleum you use for rollering is called combicolour, if you are rollering you use white spirit to thin it out
you can purchase it online, they have their own colour charts... or brewers mix it to ral codes.
toby
#4 Big Man
Big Man
    Put your trousers on---You're Nicked!!
  • 1,002 posts
Posted 14 April 2010 - 10:18 AM
toby
I am toying with the idea of spraying Rustoleum using a HVLP electric Spray system. I have sprayed Celly on a test bonnet and it comes out cracking using a 1.5 mm needle. Think Bungle had some excellent resullts using the same stuff on his camper.
Do think having read various threads on here that Rustoleum gives soem good results and is very good value with the added benefit of inhibiting rust.
#5 stickycreambun
stickycreambun
  • 1,865 posts
Posted 14 April 2010 - 10:20 AM
Exactly what im planning on doing. I know a couple of guys who have, Chris @ Retro Retrims being one of them...
I just cant justify paying for a 'proper' spray job, and dont want a cheap job so would rather try it myself!
Pretty sure Bungle rollered his.
ps. sorry just realised, the others I have seen used conventional compressors not HVLP jobbies.
Edited by stickycreambun, 14 April 2010 - 10:22 AM.
#6 mini93
mini93
  • 8,615 posts
Posted 14 April 2010 - 10:35 AM
im on about rollering anyway, one of the reasons being space confinments in my garage and also not being an extreamly clean enviroment in which compressed air would disturb greater than walking
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 April 2010 - 03:39 PM
what colour rustoleum do you want ?
if your happy with a RAL colour then go to your local brewers clicky
if you want your rustoleum mixed to a mini paint code then go to avenue coatings clicky
i painted on fibre glass, old paint and etch primer all with no problems or primer coat
your after rustoleum combi colour
#8 mini93
mini93
  • 8,615 posts
Posted 14 April 2010 - 04:16 PM
im just after black, any black will do so Thanks, nearest one is 17 mile away.
im sure the amount im after will be on other threads so ill search for that in a little bit.
the fibreglas i have is unpainted but in that white gel coat so i think ill best prime it before.
in your oppinion bungle do you think it would hide minor surface blemishes?
Thanks!
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 April 2010 - 04:53 PM
the paint sort of self levels so should help cover lumps and bumps
#10 mini93
mini93
  • 8,615 posts
Posted 14 April 2010 - 05:02 PM
thanks, thats good news!
#11 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 14 April 2010 - 06:22 PM
Moved to Bodywork, Paint and Detailing. :)
#12 mini93
mini93
  • 8,615 posts
Posted 14 April 2010 - 06:24 PM
where did i put the topic? :) i thought i put it there haha
#13 possum888
possum888
  • 19 posts
  • Local Club: Not yet...
Posted 14 April 2010 - 07:37 PM
Just found these for you
:thumbsup: http://www.instructa...o-paint-your-c/
:) http://www.instructa...With-Rustoleum/
In my opinion the second one is better >_<
#14 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 14 April 2010 - 07:40 PM
where did i put the topic? >_< i thought i put it there haha
It was in styling sir :thumbsup:.
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 April 2010 - 09:31 PM
and i posted up a rustoleum painting guide in the links section
